Results 1 to 15 of 15
Thread: battery selection optima??
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Question battery selection optima??
    hey all im in the market 4 a more powerfully battery for my car mainly for my stereo coz the lights flash at high volume and it restricts how load i wont it i was thinking bout getting an optima battery but not sure how many cca's i will need i was looking at one that is 750cca will this be overkill or just perfect. all help is grateful i drive a 89 vn btw
    cheers all
    Jan 2010
    im also wodering about a better more powerfull alternator but no idea wat 2 look for
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    D34 is the usual replacement for a commodore.
    How big is your stereo? Your lights dimming might be caused by a simple wiring issue
    Jan 2010
    iv got 2 amps, a 4 channel and a big mono block 1600watt option audio sub 2 farad capacitor. stock vs speakers in the doors (atm) and sumtin else in the rear but im changing those 2 option audio aswell and the lights only dim at high volume but my stereo can go much much louder but i dont wona blow anyfin so i keep it down so nufin dims. all the wiring for the stereo has been replaced with new stuff so basically nufin in my stereo is stock apart from the from speakers lol. i was looking at the d34 will 750cca b powerful enough
    Philthy's Avatar
    Aug 2005
    What size wiring are you using, have you upgraded the earth wires in the engine bay, and how well earthed are your amps? I assume you mean 1600wrms
    Yes the D34 will be powerful enough
    Jan 2010
    yer wrms lol havent done the engine bay just yet its all still a working progress amps are earthed fairly well iv only just getting this problem since i got the new option audio amp in so i instantly thought a more powerful battery
    Jan 2010
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I don't think 4 gauge will run 1600wrms properly, I would upgrade that.
    Also what is the 4-channel amp running if you have stock door speakers?
    Ronald Reagan (1986)
    Philthy's Avatar
    Aug 2005
    Use the biggest power and earth wires your amps can handle, then use at least 4 gauge wire for your battery-to-chassis, engine-to-chassis, and a bigger alternator-to-battery wire. Chances are your dimming will be solved
    Jan 2010
    Quote Originally Posted by acarmody View Post
    4 gauge is the biggest my amp can handle im also using 8 gauge power cable from sub 2 amp.
    the 4 channel has front and rear speakers on it with the stocky front doors speakers on the amp i dont get distortion as much with them on the amp as u would on the headunit
    Jan 2010
    Quote Originally Posted by Philthy View Post
    cheers mate ill do that do u rekon i should still get a bigger battery?
    VX Berlina
    Apr 2007
    Do the cabling first and see how it goes. If it still plays up then you can look at the battery.
    Jan 2010
    i think ill still get the battery lil extra power wont hurt. cheers for the help guys
    iaydemir's Avatar
    iaydemir is offline Donating Member
    VY V6 Berlina
    May 2009
    Hey, i had the exact same issue in my VY. I got the yellowtop Optima and the issue no longer exist's. The lights dim when bass kicks in.
    Also the standard battery was constantly charging and it kept eating away my alternator bushes, eventually the bushes wore out and alternator stops working all together, can really give you the shits.
  15. #15
    VX Berlina
    Apr 2007
    Quote Originally Posted by iaydemir View Post
    Doesn't matter what battery you have, the alternator still has to produce the exact same amount of power to recharge it. If your audio system takes 1kW/h, then your alternator has to charge back 1kW/h.
  1. Optima Batteries
    By vt josh in forum Car Audio
    Last Post: 20-06-2010, 01:54 PM
  2. Optima D34 Yellow at 13V with everything off
    By Denno in forum Electrical Wiring / Questions
    Last Post: 31-07-2009, 02:01 AM
  3. [NSW] Fs - optima blue top battery great condition cheap!
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 22-12-2008, 07:58 PM
