Results 1 to 15 of 15
Thread: Speaker Wire
    Toyota MR2
    Feb 2008
    Default Speaker Wire
    Hi,
    I'm going to replace the speaker wire in my car. The speakers I have are rated 200wrms @ 4ohm. I was thinking about running Selby Accoustic 12awg.
    25m Selby Speaker Cable 12 AWG OFC 420 Strands 2 Cores - eBay, Cables, Electronics. (end time 23-Jun-10 14:47:08 AEST)
    Recon this is alright wire? 420 strands x 0.10mm x 2 cores. 12gauge would be more than capable right?
    Deck: Alpine 9887
    Speakers: Hertz HSK165 XL
    Amps: Audison SRx2, SRx4 & Alpine M350
    Subs: 2x Alpine 10" Type S
    Toyota MR2
    Feb 2008
    I already done the mistake of buying 2x 5m of SuperCheap cable for $20 or something, and that crap most useless, the wires should snap off with the slightest bend (when out of the jacket). So I want something semi decent and 25meters for $59 is alright. 12AWG. Atleast I'll also have spare cable.
    Deck: Alpine 9887
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah that'll do fine. If you end up running 200-300wrms into each of the mids then 12AWG would be my choice.
    150db in a commodore =
    Toyota MR2
    Feb 2008
    Quote Originally Posted by holdenboy View Post
    Awesome, cheers for that HoldenBoy.
    I was going to ask if there was going to be any problems getting connectors onto the cable and then onto the speaker but I won't be running the cable so it's not going to be my problem!
    Deck: Alpine 9887
    Toyota MR2
    Feb 2008
    Just put my bid in XD $54.95 - 22hrs left. Thought I'd save my $5 ($59.95 Buyout) and I'll spend the extra $1 on Express Post
    Deck: Alpine 9887
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I would have used 8 guage, and have done in the past, and soldered rather than using connectors, crimps, ect. Connectors are fine when dealing with very small diamater wire, when you start using thicker stuff, its always best to solder.
    Allthough i have been told that 8 guage is overkill, and unnessacary. But, when is anything overkill really?
    Toyota MR2
    Feb 2008
    Quote Originally Posted by HCVP View Post
    Allthough i have been told that 8 guage is overkill, and unnessacary. But, when is anything overkikll really?
    8guage! lol. For speakers? I do recon thats overkill! But hey, why not. When people start dynamating the floors and roof that too me is overkill.
    Deck: Alpine 9887
    Mar 2009
    Cairns White Rock
    Sure why not. I can't see any negatives that could arrise from using a larger diamater than specified wire, for transmitting a signal to any component.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The negative is that it costs more and is more difficult to work with but if those issues aren't a problem for you, then there's no other reason not to. There'll be no benefit though
    Nov 2003
    VR GTS
    Oct 2009
    what about weight?
    4 runs of 8awg from boot to front will weigh a fair bit. And i'm gonna be running active splits, so that'd be 8 runs.
    an extra person sitting in a car slows it down, so will extra wire, maybe not as much, but it all adds up. 12awg is already big enough for speakers imo.
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    I'm missing something here? If you're running 200wrms per channel then you have to be running an amps. Why not just mount the amp in the boot for the rear speakers and under the front passengers seat for the fronts? With active crossovers same thing since you have to use amps just mount the crossover and amps as close as possible to the speaker. Then you just need to run the input to the area.
    Also a run of 8awg would be betwwen 0.5kg and 1kg so the weight would not be a huge issue. I think the rest of the stereo gear using active crossovers with the amps would be a lot more than that.
    QldKev
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Putting amps in different locations means more power wiring.
    I don't understand why you'd want to put your amps closer to your speakers... Speaker wire is not going to lose enough power to warrant that. I'm sorry, but this thread has turned stupid.
    Clicky clicky to see how pointless your 8ga wire over 12ga wire is for speakers.
    Toyota MR2
    Feb 2008
    Quote Originally Posted by jozlod View Post
    what about weight?
    Wow weight?
    Do you also take out your spare wheel and all your tools so you carry less weight?
    Do you think an extra kilo or 2 would decrease ur performance or fuel consumption of your vehicle by that much? you wouldn't even notice it.
    Deck: Alpine 9887
  15. #15
    Toyota MR2
    Feb 2008
    I just received my speaker wire. 25m of 12AWG cable.
    Make: Ugly Cable XD
    Cibdyctirs: 420x.10mm x 2
    Length: 25m
    Deck: Alpine 9887
  1. running speaker wire
    By arrow in forum Electrical Wiring / Questions
    Last Post: 10-12-2009, 10:29 PM
  2. Speaker wire
    By Deutscher in forum Car Audio
    Last Post: 14-08-2009, 01:39 PM
  3. Speaker wire polarity
    By Sorak in forum Car Audio
    Last Post: 01-11-2006, 12:54 PM
  4. Speaker Wire Help
    By JunyaVn in forum Car Audio
    Last Post: 09-05-2006, 02:59 PM
  5. VT speaker wire
    By mada in forum Car Audio
    Last Post: 18-01-2006, 09:54 AM
