Results 1 to 3 of 3
Thread: Power aerial with after market HU
    VZ Berlina
    Jun 2010
    Default Power aerial with after market HU
    I'm looking at upgrading the HU in my VZ Berlina and still want to be able to adjust the height of the aerial, especially when on the highway etc. It's been a while since I last purchased a HU, but I gather they still did not have the option to adjust the aerial. I was wondering if there was a some kind of controller on the market that can be attached?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    No, theres not a head-unit available with adjustable antenna controls.
    AFAIK theres no easy way to create a switch to control the antenna height. Although what i have done in the past is suggested the customer to get a head-unit with a dedicated power antenna wire (most of these will retract the antenna fully when listening to any other source than the tuner) or use a simple switch to control the antenna (on = antenna up, off = antenna down).
    But seeing as your Berlina already has the wiring antenna in place, im sure there would be a way to wire up a momentary switch (with two buttons for up and down). But i havent come across someone wanting this so i cant help with that.
    150db in a commodore =
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I wrote some basic instructions for VT/VX Berlina to add a 3-way switch to still adjust antenna height... So if the VY uses the same colour wires, it will still work. You just have to find it
    [edit]
    Got bored... Found the post:
    new headunit in VX! (yet another threed)
  1. WH Power Aerial
    By dragoon in forum Car Audio
    Last Post: 17-01-2009, 10:42 AM
  2. $$$$ for a power aerial ?
    By Northern_Union in forum Car Audio
    Last Post: 15-09-2007, 12:24 PM
  3. Power Aerial
    By SSMarine in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-08-2006, 10:38 AM
  4. 12 Volt power for VK Calais after market dizzy
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2006, 05:32 PM
  5. Power Aerial
    By Griff_Sle in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-11-2005, 09:54 AM
