ok i have abit of a problem i have a 4 channel kenwood amp kenwood KAC - M845 im trying to hook it up to a jvc kd av40 headunit, the problem is i only have line out rear on my head unit, it has no where to plug hook any rca cables to work the front anyway i could fix this?? and get all 4 working
you need two of thesejust plug these into your rca and then you will have 4
You need RCA splitters, available from all audio stores and Jaycar / DSE.
2 x RCA Plugs to 1 x RCA Socket - 300mm - Jaycar Electronics
Connect your RCA cable to the head-units' pre outs as normal. At the amp end connect these splitters to each RCA plug, then plug one of the L and one of the R RCAs into the front inputs of the amp. Plug the remaining two into the rear inputs.
150db in a commodore =
