Results 1 to 6 of 6
Thread: Amp Interfering With Radio
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Default Amp Interfering With Radio
    I have narrowed it down to my amplifier that is interfering with my FM radio. If i move some of the amp cords around it stops the radio station going fuzzy, but then when i drive around the cords must move again and it goes fuzzy again. Im sure some of you have had this problem as well, any tips on how to stop this happening? The Amp is mounted under my passenger seat since i drive a Ute.
    Quote Originally Posted by peckzz View Post
    also with this fuel thing, i had a old magna 4 cylinder 2.6 litre, and it wouldnt pull a burnout unless it was running 98 premium, so explain that 1?
    VX lumina
    Jul 2008
    SE Melb
    the antenna cable runs on passenger side kick panel, then under the dash...
    where are your wires run from/to?
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    the passenger side kick panel is exactly where my amp wire runs through. Do you think thats my problem, the amp cable is too close to the antenna cable?
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    An issue which Im familiar with is when it happened to a friend. He had the gain turned up too far on the amp. He could even here the indicators through his speakers. After he turned the gain down to a lesser level, the interference disappeared immediately.
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    thanks holdenonn, i'll give that a try.
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    theres a filter you can buy you put it on your +12v
    thats your problem
  1. VX radio
    By VX EXEC 3.8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2010, 11:01 PM
  2. VX to VY radio
    By paulbenning in forum Car Audio
    Last Post: 16-02-2010, 10:35 PM
  3. Radio Pin
    By Holdens Rule in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2008, 05:32 PM
  4. vt radio
    By ianthetiler in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2005, 06:17 PM
