ok where do people put there spare tyre if they have a full boot enclosure for there sub and amp and if some keep them in does any1 have pics of how they make it around them, and yes i have looked at and searched but nothin i could find
Most do away with a spare altogether, and just use that "tyre weld" aerosol can in case of a flat.
150db in a commodore =
ok then i might look into it but has anybody done anythin with the spare wheel still in
what ideas do you have for your setup? you might be able to conceal a space saver somewhere.
i cant see why you cant make a false floor or door, what car is this going in?
i want it fully enclosed and to cover the gas tank. so both sides and back and maybe floor so yea i would like to keep the wheel just incase its goin into a vp
Yep, I had the same dilemma as you and I am in the process of building mine. Basically build a false floor. I cut out where the spare tyre will be with a jigsaw so you can still access your spare without having to take anything out. I am going to mount my amps to each side of the boot and build a cover over them. Then I'm going to build two custom sub boxes on each side of the rear of the boot leaving space for that access hole from the rear seats. I have attached a pic I found on the net which gave me the idea. Not sure if it helps you but it sure helped me!
"Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
See my ride here
cheers mate that actually does help i will think about that idea![]()
ok i took a look b4 and the wheel on the floor wont wor i wont hav enough space it needs to be where it is now
buy a roof rack? lol. as previously said, build your design around the original spot for the tyre has got to be the easiest and most practical option.
strap the spare to your bonnet with bungy cord![]()
VZ-Rob
98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
