Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: want to make a switch so i can turn off subs when baby in car
    VR -Exec is offline VR Executive
    VR Executive
    May 2010
    Question want to make a switch so i can turn off subs when baby in car
    hey there all. i need to make a switch for my car as i have my subs but baby sue soon and i dont want the thump thump going when he is in the car but i still want my subs. i found one on the net but no idea what he meens by 12v dc switch. searched ebay but none i dont think. but i dont know what im looking for. if you have made one or something please help me. even just some advice on what switch he is talking about. lol. and could you send me a pic on this thread. any help would be reat. thanks guys
    VR Executive
    May 2010
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Its easy, just put a switch on the sub amps REM cable. That way when you flick the switch off the amp shuts down.
    Ronald Reagan (1986)
    VR Executive
    May 2010
    VX Berlina
    Apr 2007
    The REM cable is the small one generally between the power and ground cables. Just head down to Tandy/Dick Smith/Jaycar/etc and say you need a small on/off switch for 12VDC, a few amp one will be plenty.
    VR Executive
    May 2010
    i got OFC power cable & an RCA lead & another OFC power cable with black plastic and a thin blue cable for the ground. still dont have REM lol and thanks
    VX Berlina
    Apr 2007
    The thin blue cable is probably it. Cables into amp are, RCAs and speaker cable on one side (usually), and then you have power and ground cables are the same size, and a thin cable that is your REM.
    Just get something like this SPST 20A 12VDC Toggle (on - off) Switch - Jaycar Electronics and hook it inline to the REM cable.
    If your still unsure about which is the REM cable, post up the amp model and I'll find a picture.
    VR Executive
    May 2010
    ill check the site out.
    i think i get ya but my amp is audioline ALN2400 and i got the leads from autObarn as what they recommended =)
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Yeah you could use just about any 12V switch, cut the rem wire hook one end up to one side of the switch hook the other end of the rem wire to the other end of the switch
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Can't you just turn the sub down so it's nearly off or don't your gain settings allow that?
    VX lumina
    Jul 2008
    SE Melb
    bring it to autobarn and tell them to wire in a kill switch for the amp.. would cost about $30 though.
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    check ya head deck, mine has a option to turn the sub off
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    post a pic up of your amp wiring so we can tell you which wire to cut. then just put a switch in from supercheap or autobahn $5 or $10.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by ryno_vrx View Post
    2nd that, and suprised it wasn't mentioned earlier. Assuming because your running sub/amp ect, that you would have an aftermarket head unit, most h/u's do offer a sub on/off feature. So if you haven't allready checked, have a look before you go buying things and messing around with your wiring.
  15. #15
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    but im thinking wouldn't turning the whole sub off and on stop all the other speakers aswell?.. are they all hooked up through the amp or are the speakers like running from the headunit? .. Coz i would assume you would still want some noise coming from the speakers
  16. #16
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    it will turn off the whole amp..
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
  17. #17
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Quote Originally Posted by a1k3m1 View Post
    Depend on wiring config..
  18. #18
    VX Berlina
    Apr 2007
    Generally most H/U that have sub on/off controls have rear or sub RCAs. So when you switch it to off it just doesn't send a signal to that set of RCAs. It would not shut the amp off.
  19. #19
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    it depends if hes running hes sub output through the sub rcas if he has any could be rear
    pull your headdeck out get the remotewire (remote wire is not 12v its a switch wire to turn the amp on/off)
    put a lil switch on the top of the plastic compartment beneath the headdeck wella
  20. #20
    Ryley's Avatar
    Ryley is offline VZSV6
    VZ SV6
    Jun 2010
    Two Rocks/WA
    Like 3 people have said in this thread, your headunit should be able to Switch of the Subs, "SHOULD" be able to!
    Reppin' Alloytech 190/5 Speed Automatics.
  21. #21
    luke641's Avatar
    luke641 is offline ST33ZE: A Berlina Thing
    2003 VY Berlina with Calais Bits
    Jun 2010
    Cronulla
    If your using a stock HU. There is no On/Off switch for the sub. Even if there is. If you amp just powers your sub. Run a Rem/Trigger wire to under the dash, go to Repco/Jacycar and get a toggle switch ($5), and connect the wire to the switch, one end going to the amp, other end to your HU.
    I did this with me VY Berlina..
    2003 VY Berlina, First Car
    Quote Originally Posted by PaulSV6 View Post
    Quote Originally Posted by az_sv6 View Post
    19" size matters... untill someone with a 20' rolls up next to me..
    Lets hope the girls dont get confused!
  22. #22
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by VR -Exec View Post
    I will ask, do you have an aftermarket stereo or is it a stockie. If you have an aftermarket unit they generally have a sub off feature (my axis unit does) and this will not turn the amp off, it keeps the splits going nicely.
    50LTRv8
  23. #23
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I think he'll get the point guys... No need to tell him the same thing over and over when he's not even replying
  24. #24
    08 VE SS
    Nov 2009
    Why dont you install a remote bass boost.
    I got one in my car and when you turn it right down you get no bass
  25. #25
    VE 3.6 Calais V
    Jun 2010
    South East Vic
    this thread is so comical. to start off with its an easy thing to do. Secondly all you audio freaks make it sound so much more complicated than it has to be.
    I have a switch for subby. cost me 2 bucks. got audio guys at JB HiFi to fit it for free. its just a circuit breaker. got one for my GPS too, so i can have the power going to it when I am using it and no power when I am not using it (to decrease resistance). As for HU settings, they do exist but I would think that a big obvious switch is easier than MENU>SUB>ETC...!
  1. want to make heads turn a little more....
    By skysvk in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-12-2009, 06:46 AM
  2. Using A Switch To Turn Reverse Lights On
    By mrvdv85 in forum Electrical Wiring / Questions
    Last Post: 20-09-2009, 10:50 AM
  3. Headlight Switch Can only turn on parkers.
    By ZeakX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2007, 07:59 PM
  4. Replies: 8
    Last Post: 18-12-2005, 07:40 PM
  5. V6 3.8L Echotech must come out to make way for big 5.0L...Yeah baby :P
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2005, 08:31 AM
