Results 1 to 3 of 3
Thread: HELP! Can't Find Antenna Wires In Factory Harness!
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Exclamation HELP! Can't Find Antenna Wires In Factory Harness!
    I'm putting an aftermarket H/U In my vy berlina with the up/down antenna control.
    First of all, i have no white wire which is one of the two wires to adjust the antenna.
    All i want to do is connect the antenna to the acc. wire so when the ignition is one, the arial is up, when ignition is off, arial is down.
    I have the blue antenna up but no white anteanna down... What do i do?!
    Mid install here haha.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think you'll have a yellow wire with a red stripe?
    If so, connect the blue (or blue/white) wire from your head-unit to this wire. Leave the other wires, they are only for connecting to a switch to raise / lower the antenna to a custom height etc.
    150db in a commodore =
    Dec 2008
    I ended up just leaving it all together. Though when i turned the car off and locked the door, the antenna still went down? Odd, it seems to do it when i lock the car. The dash is still apart though, so i'll do what you suggested and see how that goes.
    Thanks mate.
  1. [Help] Cant find wires behind the head unit
    By Excale in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-04-2010, 09:39 PM
  2. head unit question - its not about 'wat HU to get' or 'harness wires'
    By pieman18 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2009, 08:29 AM
  3. Problem with factory speaker wires
    By ScoHar in forum Car Audio
    Last Post: 07-10-2008, 12:03 PM
  4. Factory Power Antenna answers
    By lilredwagon in forum Electrical Wiring / Questions
    Last Post: 24-03-2007, 06:20 PM
  5. can't find dash wiring harness
    By slappa. in forum Electrical Wiring / Questions
    Last Post: 01-06-2006, 08:33 PM
