Results 1 to 24 of 24
Thread: No Accecories power from the car
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Default No Accecories power from the car
    Hi guys,
    Trying to connect a new Pioneer HU to my VS commodore
    HU = DEH-4250SD
    Got the wiring diagrams and located all wires
    checked with light meter.
    Found that I have no live wire on the stock loom accessories wire. only on Constant power wire
    checked with car off.. switched to acc on... switched car completely on .. still doesnt register the light meter. why is this so?
    Round two
    just connected both constant and acc wires from the HU to the stock Constant power wire and have got power to the HU this way.
    But now have no sounds coming from the speakers.
    please help
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Check the fuse under the steering wheel, its probably blown.
    You have connected all the speakers properly?
    150db in a commodore =
    May 2010
    yes, connected all 4 sets
    - and +
    what would explain no accessories power to start with ?
    May 2010
    checked the 7.5a "Radio" Fuse it is blown
    replace this and I may be on the way to solve my problem?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If the unit powers up but has no sound, you have a speaker wire touching ground or you've blown the amp in the head unit by hooking wires up incorrectly.
    May 2010
    Ive replaced the "Radio" 7.5a fuse and now have accessories power into my HU
    Still no sound
    I Cant get power to my Amps.
    Mono amp for the sub and 4x700 amp for the speakers. both fuses on these amps are still good
    Fuse is still good in the HU
    Id be ok if i did the job myself, but im coming in half way through from someone else's job, so having a hard time tracking the wiring
    May 2010
    Ok..
    Ive found where the amps get their power
    above the battery there is a 12v ?? "box" with 4 prongs and wires clipped into it ??
    from the battery there is a wire going directly to this box
    then a thicker wire goes from this "box" to a Fuse in a glass cylinder and follows through the firewall into the car
    another wire from the "Box" is grounded very short to a bolt
    the 4th wire is tapped into another wire coming from the main fuse box . ( A Thick Pink wire)
    all is connected and fuse under the hood is intact.
    traced the wires into the Boot . 2 more quite large fuses in glass cylinders. these are still good.
    But still no power to my amps???
    Please Help.
    Greatly appreciated
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I think we are going to need pictures.
    For amp to get power, there must be a cable directly to the battery with usually 1 fuse on it close to the battery. Don't use any factory wire to power amps, they aren't thick enough.
    Ronald Reagan (1986)
    May 2010
    Photo Attached ... apologies for poor Paint editing lol
    Red cable from Battery to this mystery "Box"
    Blue/Black wire = ground
    Purple into red wire. taps into a quite thick Pink cable direct from Main Fuse box
    The insulated wire exiting the picture at about 10 O'clock is the thick red cable with goes through the Firewall.. a Fuse is attached to this inside the engine bay
    any more questions just ask
    as you can see this is why im pulling my hair out ! lol
    Attached Thumbnails Attached Thumbnails No Accecories power from the car-dscn0880a.jpg
    VX Berlina
    Apr 2007
    That is definitely not going to power a sub and may catch fire if you try. Get a real amp wiring kit and use it.
    May 2010
    This is what was in the car when I bought it .
    Had a clarion system running fine.
    Only problem the HU had a scrambled screen so couldnt see the display
    I pulled the old HU out and disconected the sub/amps from battery power.
    now when Ive come around to have the time and patience to replace the HU. there is no power to the amps
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Go to a car audio shop or find someone who knows what they're doing in person.
    Do you know what wires are required for an amp to turn on?
    I'm sorry for sounding rude but it sounds like you have no idea and playing with this stuff without the proper knowledge can end up in a fire.
    madnuts's Avatar
    madnuts is offline custom audio installer
    vz 3.6
    Mar 2009
    Penrith
    May 2010
    Did some more research.
    Ive been told
    The photo above is acting as the accessories relay and not powering the amp as such
    @StoneX. wouldnt bother me if youre rude or not. Its your rep you may tarnish. any and all criticism is welcome.
    thats why im here, to ask questions and Learn
    @madnuts. im at Adelaide, I can see youre from Sydney?. Thanks for your interest. if you can help further, Id appreciate it.
  15. #15
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    This is really simple to work out in person, it'd take 5 minutes with a multimeter.
    Get out of the engine bay, go to where the amps are... Measure the voltage at the amps terminals (measure + and - and remote/system terminals). Put the negative probe onto bare metal in the car, don't use the ground terminal on the amp.
    Amps only need 3 things to turn on... Constant power, a good ground and the remote turn on wire from the head unit. If all 3 of these are good, the amp will turn on as long as it's not faulty. So first thing you do is check those 3 things with a multimeter.
  16. #16
    VX Berlina
    Apr 2007
    Rhin0o8 have the amps worked before or have you just added them and they aren't working?
    Try what StoneX has suggested in the above comment. So to test Power cable, its DC-volts with the red probe on the power cable and the other probe on some bare piece of chassis metal. Accessory power is the same but ignition will have to be on. And Negative cable is with a Continuity test, one probe on negative cable and other on chassis.
  17. #17
    May 2010
    Thanks for your help,
    The car just got home, Ill check tomorrow in Daylight.
  18. #18
    May 2010
    I got curious to work out why this system has been wired up with that relay above the battery
    From the information i have gathered i understand that they have used this relay and tapped into the main fuse box to a wire controlled by ACC/IGN.
    whilst running 2 amps it is easing the current on the "Remote on wire" from the HU
    this way it still turns on the amp when the car is on ... and turns the amp off when the car is off
    In my system it powers the mono amp for the sub
    The "Remote on wire" from the HU powers the 4 channel amp for my speakers
    amp is powered on when the HU is switched on and powers off when the HU is off
    is this all correct ? anything incorrect, please correct it
    I may be far from an expert, but im learning alot from this
    Thanks again
  19. #19
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I cant comment on the wiring at the battery...need to see / test it in person.
    But from my understanding of that, the amps (+) terminal wires gets turned off when the ignition turns off?
  20. #20
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    unnecessary wiring just Redo it yourself if your still having problems your equiptment is faulty for shure
  21. #21
    May 2010
    Finally got power to the amps
    HU has 2 RCA outs. I needed 3 ( bloody thing was advertised with 3 RCA's thats why i bought it)
    bought 2 splitters to overcome that problem
    had front speakers going but no sound in the Parcel shelf
    swaps RCA's still nothing .
    Plugged in the Sub and it was opposite
    got sound through Sub and Parcel shelf but nothing in the front
    any suggestions?
  22. #22
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  23. #23
    May 2010
    I found a little magical thing called the "Remote On Wire" .
    HU labelled it as "System remote control" . the one ran from the amps must have fallen down inside the console.
    Plus i left it for awhile and went back to it with a fresh look.
    had other things to do on the car Top radiator hose split and drowned my engine bay.
    replaced spark plug leads before i found a stuffed coil and replaced that also.
    as for the speakers not working front and back all at once. I admit my girlfriend tweaked a few things and got it done in her lunch break today.
    This car is her daily drive so she got the logistics of the sound sorted to her specifications.
    I guess this is Problem solved.
    Now onto my VT. when i have the cash.
    Big Thanks to all the help, hints, tips.
  24. #24
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Shit hey, that old remote wire
  1. Clunk while applying power, changing power etc.
    By Skidney in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2010, 12:07 AM
  2. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  3. Power versus non-power steering columns?
    By BaggedVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 06:19 AM
  4. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  5. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
