Results 1 to 9 of 9
Thread: Is it possible to run a sub without an amp? if so how effective will it be?
    Aarony92's Avatar
    Aarony92 is offline Aaron
    VN
    Jan 2010
    Question Is it possible to run a sub without an amp? if so how effective will it be?
    yea just wondering if it would work and how it would be possible to wire it up to a head unit without a sub output. sorry if there was already a thread about this but i didn't find one so yea,
    cheers,
    VX lumina
    Jul 2008
    SE Melb
    yes you can.. but you will get next to no volume out of it..
    getting a low powered 8" sub and running it off the rear channels will work but then you need to cross it over set it up in a small box. etc.
    honestly not worth it.. better off getting a decent set of splits and running them off the headunit.. will give you much nicer bass.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by aazn View Post
    Most decent subs won't even move with only about 15wrms getting to them. Also if the sub impedance is anything but 4-ohms you risk damaging the H/U too.
    Ronald Reagan (1986)
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Put a sub on a 1W amp and you'll be surprised at the volume... Look at a sub's sensitivity rating, it's usually high 80's to low 90dB range... That is not barely moving
    But no, running a sub directly from a head unit won't sound very good as the head unit amp is not very capable of reproducing such low frequencies at any decent power level.
    Aarony92's Avatar
    VN
    Jan 2010
    hmm, thats about what i thought might happen if i tried to do it :\, i've got 4 6" speakers, 2 x 3 way 300watt and the others are 6" 2 way kicker 195 watt speakers. they sound alright so i'm a bit strapped for cash to get new splits although i'm sure they would sound much nicer.
    So i guess my idea of powering it without an amp is scrapped, do i need to get a mono amp or will stereo work? seeing stereo ones are usually cheaper ha.
    VX Berlina
    Apr 2007
    Quote Originally Posted by StoneX View Post
    I stand corrected.
    Quote Originally Posted by Aarony92 View Post
    A 2-channel amp will be OK as long as the impedance of the sub will match it. Most 2-channels produce 4-ohms when bridged, so as long as your sub is a 4-ohm SVC or a 2-ohm DVC you will be OK.
    If you tell us the sub model we can suggest some amps for it. Also Joe the car audio sponsor here has got some new amps that produce some decent amounts of power for bloody cheap.
    Aarony92's Avatar
    VN
    Jan 2010
    Well i haven't really picked out a sub yet because i'm thinking maybe a slimline sub would minimize on the space i need for it, but i will be sure to look out for the impedance of the speaker when i poke around.
    I've got about 100-200 to spend which i might have to increase if i decide on a slim sub as i've noticed they seem to be pricier. Anyone had any experince with the slimline subs? Do they sound ok?
    Aarony92's Avatar
    VN
    Jan 2010
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    A better set of fronts, and some decent 6x9's for the rear, will offer much more value than a sub at that price point.Spending $200 on some used speakers can get you something decent if your patient, and know what to look for.
    If you don't have an amplifier for your current setup, then get one. Without sufficient power even the cheapest of speakers won't reach their full potential.
    You get what you pay for, $100 worth of bass, will sound like $100 worth of bass. Factor in the overall size of the vehicle, the addition of a cheap is a very poor choice as far as component selection goes.
  1. best and most effective modification 4 sv6?
    By sv6newby in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-12-2009, 07:56 PM
  2. Effective Immediately
    By minux in forum Site Feedback / Site Problems
    Last Post: 19-10-2007, 08:28 PM
  3. New Roadside Breatho's effective 1 July
    By sixshooter in forum The Pub
    Last Post: 19-06-2006, 10:26 PM
  4. Cost effective mods
    By giannetto in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-04-2006, 10:22 PM
  5. Handbrake not effective in reverse
    By Tony2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2005, 07:58 PM
Tags for this Thread
