Results 1 to 13 of 13
Thread: high pitch whoistling from speakers
    VX executuve s2
    Jul 2010
    western australia
    Default high pitch whoistling from speakers
    hi guys,
    so when i push one of the rca cords into the amp fully channel B red off the top of my head i get a hjogh pitch whistling sound coming from drivers side speaker, increasse with revs, when i loosen it slightly stops as well as thje speaker, how can i fix this
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Are your RCAs running down the same side as your power cable? This sounds like alternator/engine whine to me.
    Ronald Reagan (1986)
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    How about you tell us what components your stereo is made up of... If you have a Pioneer head unit, I know what it is. If you don't, you need to check your amp ground, make sure RCAs are not near power cables, try other RCAs.
    VX executuve s2
    Jul 2010
    western australia
    the rca's are running down the centre and dropping down to the amp under the passener seat, opposite to power cablem head unit is alpine, 4 channel amp is pioneer sub is bolt as well as amp powering the sub, how do i fix the engine whine cause that does souybd like what it is
    VX Berlina
    Apr 2007
    OK well first check you amp ground, make sure its sanded right back to bare metal and then re-tighten that sucker. Make sure that even at the amp that the RCAs and power cable are as far away from each other as possible. If it is still there then try a different set of RCA cables and see if it is still there.
    VT S Pack
    Dec 2007
    Goldcoast
    sounds like you have a bad earth and it is trying to earth through the rcas
    VX executuve s2
    Jul 2010
    western australia
    VX Berlina
    Apr 2007
    Wouldn't hurt. Try it and find out.
    VT S Pack
    Dec 2007
    Goldcoast
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VX Berlina
    Apr 2007
    He mentioned its an Alpine H/U above, so not that stupid Pioneer RCA problem.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VX executuve s2
    Jul 2010
    western australia
    the earth is attached via the bolts attaching the passenger seat, the amp is under neath, so the earth cable l;iterally runs underneath the rca's, i will move it tommmorow see how it go's, thanks for the help
  1. High Pitch Noise from Speakers
    By gobrien002 in forum Car Audio
    Last Post: 28-07-2009, 10:00 AM
  2. high pitch sound
    By Goon in forum Car Audio
    Last Post: 02-09-2008, 05:06 PM
  3. high pitch squeeling at high speed
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 09:29 PM
  4. High pitch noise @ high rpm
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 10:00 AM
  5. High Pitch squeal
    By Phoenix21 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2006, 06:18 PM
