okay the rem port on my amp inbetwwen the ground and power ports, the cable when in is making the amp come up with protect(red light) and the sub doesnt work, how can i get it to connect i tryed bigger cables and that but nothiung make it work so power light comes on, only recently stopped working, the screw the tightens that slot is stuffed but it used to work, its a lightning audio bolt ampo(the yelllow one)( any helkp would be appreciated
hello friend,
your post is unclear. you firstly say "when in the amp is going into protect" and then say "nothing makes it work so power comes on". Please clarify - does it remain in protect?
generally, if the protect light turns on that would mean the remote wire is connected and assuming power, ground and sub are connected correctly, then one must reach the conclusion that your amp is cactus.
My apologies
"The crisis of today is the joke of tomorrow" HG Wells
Have you changed any speaker wiring? Maybe a speaker wire is grounding somewhere.
Ronald Reagan (1986)
the REM(remote) connection is ####ed basically, screw is so threaded that when placed in my amp is in protect as it wont tighten to enable a proper connection and be on power
new amp here i come, any recoomendations to power a sub, good cheap ish amps
What sub is it powering? I'll be able to give a pretty good deal on a few decent mono's
its a lightning audio sub i think its the promo sub, not 100% sure tho, the amp that was powering it atm was a lightning audio amp b2.300.4
This amp? Lightning Audio B2.300.4 Car Amplifier - Car Amplifiers - Shopping.com That isn't nearly powerful enough to power a sub. Could well have cooked it trying.
Is one of these the sub you have? Lightning AudioŽ : Product Details Lightning AudioŽ : Product Details They are the only 12" subs on their website, although that amp isn't mentioned either.
Can I suggest this amp Shopping Secure - Car Audio Specialists - Option Audio OAX502 if you are up for a replacement? It doesn't give RMS power ratings on the Lightning website, but this would be perfect for a basic sub, either the single 4ohm, or the more powerful 2x4ohm
its this amp cuurently Lightning Audio B2.300.4 - Car Amplifiers
and neither of the subs it an older one not the new la series
amp 500 rms
