Results 1 to 11 of 11
Thread: Replacing Car Stereo for Commdore VE - V6 - 2008
    VE Coomodore V6
    Aug 2010
    Gold Coast
    Default Replacing Car Stereo for Commdore VE - V6 - 2008
    Can it be done?
    I have spoken to a few people who install stereos and have said that they wont do it, they made sure when they monopolized the stereo systems that you get stuck with them
    I hope not as the sound system is terrible.
    Any ideas???
    Thanks
    Em
    VZS-Ute06
    Aug 2006
    Western Vic
    Contact Phreddy
    Welcome to ASR Audio & Electronics Home Page
    he can mod the HU with RCA outputs for a fantastic clean sound
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Other than getting your head-unit modified by ASR Audio, there is three other options available at the moment:
    1. Install a high quality line out converter (LOC), something like the Rockford Fostgate 3sixty or Audison BitOne. They arent cheap but give you upgraded sound quality and the connection of aftermarket amps etc.
    2. Install an aftermarket head-unit in the glovebox, can be done quite easily but means you cant control the unit when the glovebox is closed (remote wont work through glovebox).
    3. Install an aftermarket head-unit below the stock stereo (where the ashtray area is), this option is not easy nor cheap, but its a more practical option over the glovebox.
    150db in a commodore =
    2010 VE International Sportwagon
    Apr 2010
    I have put in new speakers, an amp and sub but at any type of decent volume the sound distorts from the main speakers. When we hook the system up to an external high quality car audio system it sounds great so assume it is the crappy Blaupunkt head unit - does the Rockford Fostgate 3sixty or Audison BitOne fix this - as you say they aren't cheap and I don't want to commit to find it doesn't fix the problem. I am working with an Omega system. Thanks.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by Sportwagon View Post
    How did you hook up the amp? LOC? High-level input?
    Also how did you set the gain on the amp? You should have it set so that it achieves the maximum power at about 2/3 or the H/Us maximum volume. Otherwise you are stressing the H/U internal amp and will get bad quality.
    Ronald Reagan (1986)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    The Audison BitOne and Rockford 3sixty do improve the sound quality / volume, but not as much as a very good aftermarket head-unit ($400+). I am led to believe these units can also integrate an iPod / iPhone etc.
    Personally, i would stick with the stock unit, the aftermarket options arent great at the moment.
    Apr 2010
    Installer used a PAC LC2 LOC on high level input. He tested multiple gain settings, even without the LOC, different speakers, different amp and still the same result. He concluded that the signal from the Blaupunkt was "dirty". . It's all OK to about 22 and then the speakers sound crap. Any suggestions appreciated.
    VZS-Ute06
    Aug 2006
    Western Vic
    You need to turn off all auto adjust levels
    just a straight throu flat signal - NO volume compensating - NO presets ie rock, jazz, vocal, etc
    VZ-Rob
    VH, VL, VT, 74 monte carlo,75 dropped effy
    Aug 2009
    city of gosnells
    kicker makes a unit that you can wire in and keep your stock radio, just look it up on their website, im pretty sure thats what its for...
    2008 VE Omega
    Aug 2010
    Aug 2009
    city of gosnells
    yes, thats the one pete101, i havent used one myself but looking at the description on their website i thought thats wat it was for?? is that wats its used for???
  1. Replacing Standard Stereo for an aftermarket
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-05-2010, 10:44 PM
  2. Replacing VZ factory stereo
    By 40/20 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2009, 08:01 PM
  3. Replacing stock stereo?
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 10:30 AM
  4. Replacing the factory Stereo
    By girlracer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2006, 07:59 PM
