Results 1 to 7 of 7
Thread: Amp under seat?
    Vy Sv8
    Jun 2009
    Default Amp under seat?
    Ok in my boot i have a great big dirty gas tank, so i was thinking instead of running wires from my rear door speakers to the boot just run them under the passenger front seat to my amp. by doing this and running cables to my sub in my boot will it affect the performance of my sub??
    and is there somewhere easy i can tap my remote wire into??
    i cbf pulling my headunit out and searching through the 20-30 wires behind it.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Remote wire to the ignition. Behind the h/u it will porobably be blue/white trace.
    All good to have amp under your seat won't affec the sub having a longer speaker cable rather than shorter.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Vy Sv8
    Jun 2009
    Thought the cable would heat up??
    causing more resistance.
    equaling less doof??
    Dec 2008
    The cable won't heat up mate (we are talking about the speaker cable here right??) but make sure it is of a proper guage.. to be on the safe side for decent subs/decent power you should be using an 8 or 10 guage speaker cable. .. What power will be running through the cable?
    VX lumina
    Jul 2008
    SE Melb
    nothing wrong with running them under the seat... just make sure you use the passenger seat and when you take the seat out, DO NOT TURN THE CAR ON IGNITION.
    if you want a easy remote, remove the glovebox, and the bottom panel in the middle (center console) and the radio loom is there, tap into accessories.
    VZ SV6
    Jul 2010
    Mandurah
    with the remot wire in my only vt i had trouble gettin my old h/u to turn amp on so i jsut connected it to the the fuse for the ciggerette lighter and it worked fine
    IF YOU WANNA REV IT CHEV IT
    VT Executive S1
    Mar 2009
    TAYLORS LAKES
    i got 2 12" subs in my boot with a gas tank and it sounds sick as! and for the speakers i got an amp under the passanger seat as well so u can still do it even if u have a gas tank or not!
  1. VS ute bench 2 seat to bench seat conversion.
    By dazzavs00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2011, 07:20 PM
  2. [QLD] Wtb-vx ss s2 r/ft seat & rear bottom seat swab + other parts
    By VTLS1 in forum Swap / Wanted to Buy / Trade
    Last Post: 21-07-2010, 04:44 PM
  3. Who's done the Coulson Foams TO Standard Seat VX Seat frames??!
    By SSINZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2010, 10:02 PM
  4. [SA] WTB: VR-VS Bench Seat & Bucket Seat for VP Ute
    By CirrusC2 in forum Swap / Wanted to Buy / Trade
    Last Post: 14-04-2010, 02:42 PM
  5. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
