hey guys im a bit stuck on my install, regarding what size power wire i will need for my amps
i will be powering
1x mrp-m1000 (1000wrms,1900wmax)
1x 600w 4 chan amp i have laying around
the main cable will run from teh battery approx 4-5 meters into a distrbution block into the boot then about 1m to the amp it self
could some recoment wat power size wire i should use
thru my reserch i found that
for mrp m 1000 i will want 2awg
and the 4 chan 8gauge
tho this is running 2 power cables from the batter ( is that safe, will it interfer with each other)
and i would also like to introduce a 4 farrad cap into my system
thanks in advance
Darren
IF YOU WANNA REV IT CHEV IT
use the biggest ones you can
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
Run one big power cable down to distribution block and then split them up. I would run 0-gauge to disto-block then 0-gauge to mono and 4-gauge to 4-channel amp, overkill probably but will basically never need upgrading. Also 2-gauge is damn hard to get.
Also don't waste money on cap, get a bigger battery if you want to. Also look into the BIG-3 upgrade.
Ronald Reagan (1986)
I'd use 0g to a distro block, then the biggest cables you can to each of the amps.
You don't need a cap either...
hmm foound a nice dist block that sound stream does looks mine and it also grounds aswell
2x 0 awg for ground and batt +
and 8x 4awg for the outlets +/-
Are you sure it does power and ground? Or can be used for power or ground? Got a pic? Usually these distro block are near solid metal so I can't see how it could do both.
http://www.dnaaudio.com.au/productvi...&product_id=33 This is the kind of thing you are looking for
yes it does it look pretty kool actuly here a link
Power Plant Processor
if i do get iill get the 1st one
Woah, thats the first I've ever seen of them. I don't understand though...the little bit on the end with the terminals would be the only bit that actually does anything. Have they just attached an empty case with some pretty lights to the rest of it?
Also, in the specs it says "power/ground inputs: 1". Does that mean 1 input total, or is it 1 power and 1 ground as you thought before?
What are they asking for them? Keep in mind that its a $10 part most people would use
im gonna assume it has same function as 2 distro blocks that have a gorund side and a power side the looks clean and fancy worth looking into a price would make my system look pretty fancy and would math the blue paint job of car and blue trims in boot install
Have a look here, it shows you what it does. http://www.soundstream.com/manuals/2...er%20Plant.pdf
Yes it has all the inputs and all the outputs in one.
