Basically I am looking for someone who can repairs amp in Brissie.
My front speaker amp decided to stop working the other day, so last night I pulled it out and made sure all the cables were well and good, turns out the fuses were blown. So today I go to Supercheap and get some new fuses, I slot the first one in and it sparked but nothing big, I had forgotten to disconnect the battery so I proceeded to do this, slotted second fuse in, then replaced first fuse since it had blown. I went and hooked the battery back up and my amp starts smoking quite a bit, so I run and disconnect battery, remove both fuses (which were still good) and then disconnect the amps power cable from distro block.
This is what I got when I cracked it open just now.
I have had some rare occurrences with this amp where it will get quite hot and shut off, but while its a 4-channel and I'm running it bridged, its rated at 300wrms@4-ohm x 2 bridged and I'm only running it at about 150wrms x 2, so I'm not even maxing it out.
Ronald Reagan (1986)
