hey guys,
just a small problem, got around to installing my new dvd player today
now ive just noticed that its not keep its memory, like time, and the cd/dvd starting back at the beginning...what would be the main cause of this?
im thinking the constant power wire?? ive double checked all my wiring, i soldered them 1 by 1 reading the manual as i went
any help would be appreciated
Thanks
Check your fuses under the dash firstly. Its possible youve touched either the constant or acc wire whilst soldering. Theres two fuses in the panel so make sure to check both.
Other than that you may need to remove the stereo and re-check the wiring / check the unit's fuse if applicable.
150db in a commodore =
did you use an iso adaptor that you soldered to, which then plugged into the factory harness?
if so, swap the power and constant wires around. common problem with vy/z + iso harnesses.
cheerz buddy will check that, i had a adapter which i bought which plugged straight into the loom, and i soldered them outside on the table so ther wasnt a chance on shorting out etc im fair certain the wires are correct, it was even labled on the adapter and the new wires on what they where
yep, swap the constant and accesories around, red and yellow. not sure why, but holden have them opposite to standard iso
sweet, will do....ah now the fun starts agen...pulling the dash apart![]()
woooo, and it workscheerz Hak
