Results 1 to 8 of 8
Thread: Replacing VE Amp.
    VE Calais 6.0
    Aug 2010
    Default Replacing VE Amp.
    Hi Guys..
    I have a VE calais and I have replaced all of the 6" speakers to after markets. Much better.
    How I have ordered some 8" JL Audio subs to replace the stock subs too!
    How my questions is... how do I replace the stock sub? can I use the cables that goto it and then wire them into the sub?
    I got a Kicker ZX300.1 Amp to use.. but my concern is that the back amp is powering the other speakers too.. but im not sure.
    Any one know?
    VE Calais 6.0
    Aug 2010
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Did have something written up but had to go help a mate.....sorry.
    If you're wanting to replace BOTH the stock subwoofers and stock amplifier, then i would suggest running new wiring (esp. power / earth) as the stock amp wiring probably wont support the extra power of the new amp.
    AFAIK the amp only powers the subwoofers, while the stereo's internal amp powers the speakers. So if you were to disconnect the amp only the stock subs will be affected.
    If you want to replace just the stock subwoofers you'll just need to remove the old ones and install / wire up the new ones.
    150db in a commodore =
    VE Calais 6.0
    Aug 2010
    Okay, if i remove the stock ve amp, use its audio and access cables, and run new power and audio... will it work?
    I have been told you f*&% the car if you do that.
    I have the subs now too, need to know how to remove the seats to replace the speakers
    VE Calais 6.0
    Aug 2010
    VE Calais 6.0
    Aug 2010
    Nevermind.
    *Removing Holden VE Back Seats*
    The flat part is removed by yanking it up by the two clips, (right and left seats)
    It then just lifts out
    you then remove 4x bolts which remote the left and right back seats to access the parcel shelf.
    the next part is the more confusing.
    I need to figure out which cable to plug the amp into...
    Can I plug it into the current cables which going to the current subs? Then run cables to the new subs?
    Cheers.
    Calais57's Avatar
    Calais57 is offline Donating Member
    VE Calais V 6.0
    Jan 2009
    Blue Mountains, NSW
    crackah,
    I know this was afew months ago but can you tell us how this all went? And any suggestions?
    Thanks
    07 VE SV6
    May 2010
    Gold Coast QLD
    How did u go? Ill be doing the same roughly VE SV6 commodore. replacing all speakers and subs and amps.
    1) Does the VE SV6 have a seperate amp? or the amp is in the head unit?
    2) How many subs does the VE SV6 have?
  1. Replacing CAS
    By Mikel. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-09-2009, 02:19 PM
  2. Replacing MAF with MAP on a VS
    By ephect in forum Tuning
    Last Post: 30-06-2009, 06:00 PM
  3. Replacing oil switch (ebay one) and replacing cup holders???
    By BlackCaprice in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2009, 03:50 PM
  4. when replacing a cam
    By mofo sixx in forum General
    Last Post: 24-03-2009, 10:34 PM
  5. Replacing 3.8L with 5.0L!!! Help?!?!?!
    By Berlina... in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2006, 09:45 PM
