Results 1 to 3 of 3
Thread: VT Commodore No sound Left Front Speaker
    VT S2 3.8 & VT SS S2
    Jan 2009
    Default VT Commodore No sound Left Front Speaker
    Hi everyone just run into a problem with the car audio install.
    Put in a Pioneer DEH4250SD. 4 stock speakers to the head unit. Problem I have is when I have the speaker wire for the front left in the Pioneer head unit NO sound comes out. When I remove the wire then I get sound from the other 3.
    Could this be a stuffed speaker? It was working before......
    Any help much appreciated
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Most likely the speaker wiring for that speaker is touching ground somewhere. Pioneer head units will mute the output when a speaker wire is being ground to prevent damage to the internal amplifier.
    Jan 2009
    Can't think where. It is the original speaker wire and soldered on to the Pioneer harness and then taped up. Very odd indeed had another look at the wiring and can't find a fault unless something has changed on the speaker end. Might have to try a whole new speaker wire.
  1. interferance on front left speaker?
    By Big_Simmo in forum Car Audio
    Last Post: 11-07-2010, 08:18 PM
  2. High pitched sound coming from front left wheel when turning
    By RonMan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 10:45 AM
  3. Replies: 6
    Last Post: 15-11-2008, 04:27 PM
  4. strange sound under the front left during right hand bend and turns?
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2008, 09:43 AM
