So since installing my head unit (which looks so hot) I've noticed that theres a particular wire that goes from head unit to amp called 'remote', im sure you all know that.
Anyway, since i'll be running 2 amps and 2 subs (setup seen here) i was wondering. which amp do i run the remote wire to? Or do i splice it and run a secondary wire off that one and run it to both amps?
Also another thing i just remembered, since ill have 2 amps does that mean ill need two wiring kits and two sets of wiring running from the battery? I have a 4gauge wiring kit, if that helps at all.
Thanks!
06' VZ Commodore
You can easily run 2 amps off the one remote wire, no problems. So splice it too each amp.
A single 4 gauge kit should suffice, just get a distribution block and run some 4-gauge to each amp, but will need a ground for each amp. I have my distro block under my rear seat.
Ronald Reagan (1986)
Sweet!! Thanks for comfirming my thoughts![]()
06' VZ Commodore
they also say that the wiring coming off the distribution block to the amps should be the same length,
LIFES A GARDEN, DIG IT..lol
