Results 1 to 13 of 13
Thread: VS Door speakers-Help please
    VS Berlina S2
    Aug 2010
    Default VS Door speakers-Help please
    I've searched for so long on the forums and google and i can't find a VS how to guide for taking off the front doors. I reckon it would be pretty simple but i just don't want to pull something to hard and break a clip or something and have it looking dodgey, any help, or direction would be greatly appreciated.
    vp calais
    May 2006
    adelaide
    it fairly easy dude, 3 long screws in the bottom of thr door, 2 in teh pocket, i under the grill. remove the single screw from the part of the air vents the contacts the dash, remove the cover and the inner vents they just clip in, the undo the 3 screws inside the cavity remove the black plastic shroud from in front of the mirror you should be able to remove the top plastic section now, remove the cover for the grab handle and undo the 2 screws inside it now u can take the door skin off, bit of messin around but just take ur time and check everything before trying to pull it off the only thing u need to pull off is the skin itself as its the only thing with clips
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    VS Calais
    Apr 2010
    Dandenong, VIC
    the hardest bit that i find is trying to remove the door lock tab, i always end up snapping my locks and have to go to the wreckers and buy new ones.
    Quote Originally Posted by minux View Post
    I think Camrys only stay afloat because Indians seem to be sponsored by them...well in Vic anyway.
    vp calais
    May 2006
    adelaide
    oh yer the door locks, i suggest getting a set of picks from repco pick the bottom right corner of the orange slip lift it just enough to lift it out then undo the screw behind it
    VS Berlina S2
    Aug 2010
    Mar 2009
    Cairns White Rock
    I'm yet to find a tool that pops the tab up without atleast taking small chip out of the plastic.
    When i did mine, i sanded the tabs back and re-painted them before putting them back on. Being as pedantic as i am, i then had to remove the rear ones and do them aswell, as they no longer matched the fronts haha.
    Becareful removing the trim itself once you have unscrewed everything else. It is held on by about 10 or so little lugs. They consit of a lug attached to the trim itself, and a round hole which they pop into in the metal section, the door itself.
    If you bust some of them, they are still available through Holden fairly cheap.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    The red tabs are about 70c each if you are worried about them. I usually keep a few spares
    VS Berlina S2
    Aug 2010
    Mar 2009
    Cairns White Rock
    Better off just sticking some jaycar splits or something similiary priced in there, and spending the extra on Dynamatt, decent amp , ect.
    There's a point where you have to spend a certain amount to get decent quality, but beyond that can be a lot spent, for what seems like a little gain.
    VS Berlina S2
    Aug 2010
    VS commodore executive
    Mar 2010
    Mar 2010
    Those pioneers are great but hcvp is right better off with an amp first then move into high quality splits=D
    Jeremy Clarkson.....Speed doesn't kill....stopping suddenly from speed, that's what gets you.
  1. vz door speakers
    By CoJang in forum Car Audio
    Last Post: 09-03-2010, 05:51 PM
  2. best speakers for vx door
    By vx aiden in forum Car Audio
    Last Post: 08-11-2009, 05:57 PM
  3. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  4. vt door speakers
    By gorno in forum Car Audio
    Last Post: 01-05-2007, 06:57 AM
  5. vs in door speakers
    By Hinchman in forum Car Audio
    Last Post: 19-06-2005, 10:06 PM
