Results 1 to 7 of 7
Thread: What amp do I need?
    VS Ute
    Feb 2010
    Wollongong, NSW
    Default What amp do I need?
    I am thinking of upgrading my pretty average sound system in my VS ute. Currently has an old JVC head unit, 6" JVC splits and a sub next to the fuel tank which had its wire cut by the previous owner, im assuming when he/she removed the amp.
    What amp would i need run all the speakers? Im not looking to spend a fortune, if a second hand one will do the trick im happy with that. And how do you run the splits off the amp? Im keen to give it a go for myself.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What model speakers and sub?
    You could use a 4 channel amp to power the fronts and sub but I can't tell you a power rating until I know the speakers. You could always just go for as much power as you can find Jaycar 4x100 are decent amps for the money... Otherwise I'd be looking for a second hand 4 channel.
    VS Ute
    Feb 2010
    Wollongong, NSW
    Im not sure what model they are, haha I just had my door trim off a few weeks ago too. They arent anything special and arent new though. I could look, but does knowing the model only tell you what power i need? Because i have looked on ebay and seen cheap, powerful 4 channel amps there. If it is too much power i can always just turn it down haha. How much power would an average set up like mine need? So do i need a 4 channel?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Speakers probably 50W per channel minimum and you really need to know the sub power rating because a 50x4 amp when bridged can make from 120W to 200W depending on brand... But that doesn'dthelp if your sub is rated at 400W.
    If you can't find model numbers, I'd just grab a 100Wrms x 4 amp to be safe
    VX lumina
    Jul 2008
    SE Melb
    a 4 chan would be ideal if your running 2 speakers and a sub.
    Response Car Amp 4x50WRMS - Jaycar Electronics - 50wrms per chan
    if you want to go better..
    Response Precision 4 x 100WRMS Class AB Amplifier - Jaycar Electronics - 100wrms per chan
    i dont see a point in getting a full range amp for a basic setup.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    VY Berlina V6 / R31 Skyline
    Dec 2008
    o.O wow thats cheap for GZ gear!
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
Tags for this Thread
