Results 1 to 9 of 9
Thread: Amplifier Not powering ON :(,
    Aarony92's Avatar
    Aarony92 is offline Aaron
    VN
    Jan 2010
    Default Amplifier Not powering ON :(,
    me and my mate wired up an amp for his sub in his car, with 50A cabling. connected it to the battery and nothing. Do we have to connect a wire from the remote connection on the amp to the head unit for it to turn on? I don't know a whole heap about amps but i assumed once a 12V supply was connected it should turn on?
    Help appreciated, especially since we're doing the same to mine.
    Thanks guys,
    VY SS
    Jun 2006
    Albany
    yes the remote connection on the amp goes to the headunit so when you turn the headunit on the amp will turn on this stops the amp from draining the battery when the car is off.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Yea I did the same last nite
    U need the remote wire
    It comes with the wiring kit
    If nit just run a single wire
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Aarony92's Avatar
    VN
    Jan 2010
    Ah, thanks guys i figured it was a relay or something. oh any idea what power rating cable i need? just a low one?
    91 vn s
    Jun 2009
    Adelaide, SA
    yeah its only a low amp 12v signal that goes thru that cable. i think even a single length of speaker wire would do the job. They usually come bundled with amp wiring kits, or as an attachment on the rca cables
    Aarony92's Avatar
    VN
    Jan 2010
    cheers guys, might just grab some standard 25a cabling so its nice and solid. And na my amp didn't come with any wiring cause i bought it second hand, $30 for a 600w. not bad i say haha.
    VK SL + LH Torana + VZ Crewman
    Sep 2010
    25amp cable for that is massively overkill. The signal cable uses a maximum of 500ma to turn on the amp. The type and quality of cabling here makes absolutely no bearing on the quality or volume of sound.
    Aarony92's Avatar
    VN
    Jan 2010
    oh wow, .5a is nothing. thanks that'll save me a bit, going to buy my cables today thanks lamo
    Aarony92's Avatar
    VN
    Jan 2010
    Rigged mine all up today, sounds amazing. Thanks guys
  1. over-powering slimline sub bad?
    By crawfy in forum Car Audio
    Last Post: 04-08-2010, 11:01 PM
  2. Powering splits.
    By jaisvz in forum Car Audio
    Last Post: 02-12-2009, 10:31 PM
  3. Amp not powering up
    By VNexecutive in forum Car Audio
    Last Post: 18-02-2007, 03:51 PM
  4. Powering subs
    By manvr in forum Car Audio
    Last Post: 08-06-2005, 03:16 PM
  5. Alternate powering
    By vpwgn in forum Electrical Wiring / Questions
    Last Post: 29-12-2004, 01:09 PM
Tags for this Thread
