+ Reply to Thread
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 101 to 125 of 130
Thread: VK-VZ Stereo wiring colours.
  1. #101
    vz Sv6
    Dec 2009
    yea their was two so thats why im puzzled, im new to all this, whats a test light, and where do i get one?
  2. #102
    holdenboy's Avatar
    holdenboy is offline Custom Car Stereo Systems holdenboy Calais
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Here is a test light from Jaycar. Although you can get similar test lights from super cheap auto etc.
    Basically, you attach the alligator clip (earth) to a metal section of the car.....the outer part of the antenna plug also works as an earth if you cant find something to clip it onto to. Then just "probe" the wire where it goes into the back of the stereo plug (if you havent cut it off already). If it has power going to it then the light should light up, if it dosent move onto the next wire.
    If you need anymore help, dont be afraid to ask.....no matter how silly it might sound.
    150db in a commodore =
  3. #103
    VZ
    Feb 2010
    Can someone help me out....
    I've just put a new stereo in my VZ commodore wagon but for some reason i can't find constant power.
    I've looked over your wire colour charts and i have a multimeter in hand!!
    There is NO orange / white wire in the factory loom .... The Yellow accessory wire had 12v but now i can't get it. I could have blown a fuse ..... ( if so where is the stereo / acc fuse on the VZ ? )
    thanks!!
  4. #104
    Vt Berlina 1998 Not my dp
    Jun 2009
    Frankston
    what is the negative colour on a vt berlina s1
    Quote Originally Posted by Cobez View Post
    You sir, are as gay as aids and as camp as a row of tents. You also fail..
  5. #105
    Jun 2009
    Frankston
    installing my new h/u it asks for all of these wires
    to ignition key
    to power antenna
    to + on battery
    to - and ground on battery
    what colours will this be in a vt berlina s1??
  6. #106
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling.... calais_cruzin Berlina
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Accesories - Yellow , thats ur ignition wire
    Constant - Orange/White, thats ur batt wire
    Earth - Black/White, theres ur ground or just connect to bare metal
    Antenna up - White (VR onwards) connect these (up/down) two toghether to ur ariel wire, pretty sure thats how i did iton me bro's stato
    Antenna down - Blue (VR onwards)
    ________________________________________
  7. #107
    Ando227's Avatar
    Ando227 is offline Serious? Ando227 Executive
    Vy Series II Ute
    Nov 2008
    Lightning Ridge
    Is someone able to tell me as to how to wire the head unit so it doesn't cut out and re-start it self every time i open the door? (unit is wired in and working along with subs, but i'm tired of having to reset all the setting on the HU when i go for a drive).
    Driving a 2006 VZ Acclaim
  8. #108
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer crazyspoon05 Caprice
    The 'Bizta' VNVPVR Wagz
    May 2006
    Hey all
    What wire do I tap into to utilise the factory electrical aerial with an aftermarket Sony headunit in a VN Commodore that has a remote antenna wire (so it can still be moved via the dash buttons) ?
    Thanks in advance
    If ignorance is bliss why aren't there more happy people around ?
  9. #109
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You need to connect the blue (or blue/white depending on head-unit brand) to the yellow with a red stripe wire.
  10. #110
    May 2006
    Cheers mate
    Connected the blue to the yellow w/ red stripe and antenna raises when radio is selected but then goes straight back down again (can raise antenna via cluster button but still doesn't stay up)
    Is there another wire I should be tapping into as I'm assuming antenna module is thinking radio is turned off so is retracting aerial ?
  11. #111
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Interesting, make sure theres power going to that yellow / red wire while the antenna retracts.
    Could also try connecting the yellow / red wire to constant power (orange / white) and see if it still retracts.
  12. #112
    May 2006
    Thanks again for your help
    Turned out to be a faulty antenna module so now working as it should.....
  13. #113
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    often times the constant wire is Orange with a black trace.
  14. #114
    vy ute
    Jul 2010
    forest lake
    i own a vy ute , putting sub and amp in
    runnning amp from battery
    what colour are the speaker wires?? so i can join the line out convertor to my stock head unit.
  15. #115
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
  16. #116
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Putting a new headunit in my VY - though i don't have an organe/white wire for the constant power. I have two orange/blacks
    I also have yellow, yellow/black and yellow/blue
    Do i use the yellow for acc.? Not sure which to use for main/constant power..
    EDIT: Just saw a post a few up that said it can often be orange/black. Do i se the orange/balck for my constand power?
    Cheers.
    Quote Originally Posted by savage1987 View Post
    Gasket free: cereal box.
  17. #117
    VX acclaim S2
    Oct 2009
    Im doin a mates vz n it has two blue with black stripes? N couldnt find antenna up down, but it works on yelllow with red stripe, but radio still Fuzzy... Help?
  18. #118
    VL Commodore
    Dec 2010
    Im seriously struggling
    Have an 86 VL and trying to install a JVC stereo CD player
    HAve looked at the colour guide but mine doesnt have an orange.
    Mine has...
    Yellow
    Grey
    Black
    Pink
    Cream
    Light blue
    Green
    Well the male harness does anyhow
    My JVC has
    Yellow
    Red
    Black
    Grey
    Gray (Black stripe)
    Purple
    Purple (Black stripe)
    White
    White (Black stripe)
    and the 2 blues
    What do i connect with what? Cos im failing to get it going
    Is there some issue about connecting a direct line to the battery for voltage on VLs?
  19. #119
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    You also have to rewire the speakers as the factory wiring has common ground , not going to end well with an after market unit.
    Right click save as . .
  20. #120
    VX S-PAC
    Jan 2011
    Melborune
    on a vx what colors the constant or the wire that saves memory?,Ive wired it up but every time the ignition is switched off the CD players memory is gone.I've wired the accessory and constant both to yellow but this doesn't save memory
  21. #121
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    Constant is orange , thats goes to yellow on your deck.
    Acc is yellow on the car , goes to red on your deck.
  22. #122
    Nic92's Avatar
    Nic92 is offline http://#####s.justcommodo Nic92 Executive
    VY S
    Mar 2011
    WA
  23. #123
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW D3CID3R Calais
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Quote Originally Posted by Nic92 View Post
    what about the steering wheel controls... in a vy
    what about them...
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
  24. #124
    Nic92's Avatar
    VY S
    Mar 2011
    WA
    Quote Originally Posted by D3CID3R View Post
    what about them...
    i want to know which wire it is... without taking the steering wheel apart
  25. #125
    Nic92's Avatar
    VY S
    Mar 2011
    WA
    WRONG!!!
    Accesories - Yellow
    Illumination - Brown/White
    Earth - Black/White
    12V OUTPUT - Yellow/Red
    Radio Mute - Yellow/Black (VT onwards)
    Illumination OUTPUT - Grey (VT onwards)
    my constant was yellow
    and ignition is red
    and others havnt checked
    ^VY commo
+ Reply to Thread
  1. vt stereo wire colours
    By t-rev in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-03-2008, 12:19 PM
  2. VB car stereo wiring colours?
    By Izual in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2007, 10:27 PM
  3. help-wiring colours
    By pr0n in forum Car Audio
    Last Post: 08-12-2007, 01:55 PM
  4. vc wiring colours?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-06-2006, 11:09 AM
  5. Need help with car audio wiring colours
    By Doep in forum Car Audio
    Last Post: 01-07-2005, 08:25 AM
