Results 1 to 4 of 4
Thread: Intermittent Speaker Crackling
    Dec 2006
    Default Intermittent Speaker Crackling
    Hi,
    My front VZ commodore speakers are currently experiencing an extremely bad crackling sound intermittently (through radio & cd). For the last few months, one of them has also been having trouble turning on unless I have the volume up very high. The speakers are running through an amp. Sometimes its a few days between the crackling, however it's been quite persistent lately.
    I've attached a sound clip of what i'm trying to explain. Does this sound like an issue with the wiring, or are the speakers just blown?
    Thanks.
    Attached Files Attached Files
    91 vn s
    Jun 2009
    Adelaide, SA
    That doesn't sound like any voicecoil crackle i have heard before, i could almost say its a wiring issue - as in 'the speaker is only just connected by one stand of wire' kind of noise. Sounds like static - a bad arial reception static. Try playing something more defined than vocal - perhaps a tone or some technoish stuff to hear if the speaker is coughing. Also try wiring another speaker to the amp in place of the dodgy one, thall help you isolate the problem
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Have you checked your earths mate? And made sure none of the speaker cables could be shorting out by touching the chassis anywhere?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    96 VS SII 5.0 Calais
    Apr 2009
    Melburn
    what you could also try (if you cbf) is cut the existing speaker wire from the head unit that runs through the door, and run a new one to each speaker.
    does it crackle when you open the front doors? speaker wire could have a split after years of the door opening and closing and could be causing the cracking.
  1. Crackling on cold start
    By TinSnips in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-04-2010, 10:21 PM
  2. exhaust crackling louder ?
    By simoo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-08-2009, 07:09 PM
  3. Crackling with low volume
    By Chirpstr in forum Car Audio
    Last Post: 09-09-2008, 10:32 PM
  4. Exhaust Popping/Crackling!
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2006, 05:08 PM
  5. Crackling Sounds and No Fire
    By pacey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-06-2005, 04:00 PM
