Hi all, i got 2 clarion PA15's in my car, running off a kenwood mono block amp.
Problem is when im driving, or car on idle the subs turn off. The map is stil on tho. So what i have to do to get them back on it turn off car and turn on again.
IM runing 8G writing from bat to amp, and using standard bat for car.
I know i need minium 4g buh i think the problem is the stantard batt.
will it be a good idea and cheaper idea to buy a second normal batt and place it in the boot and connect it parallel, instead of buying a heavey duty batt. (as u can see i think the problem is im not getting enough power, as wen the system is on full the lights go f0orm normal to dim normal to dim)
also if anybody knows the price of those heavey duty bat. thanks
(also this morning my car wudnt start, batt was flat as, but i lefted nuffin on,, last night system was on whole night n turned off 4 times, i think i really drained the bat.
are your subs wired in right? i just had a problem with mine cutting off, added a another type r and wired it wrong for a bit, would pplay but when it hit 20, they both cut off and needed a restart of the car.
fixed the wireing and now they go nuts
they r wried up correctly, im pretty sure but jst the main power n ground cable are to thin.. is only problem wit wiring
First upgrade the wiring, then make sure the gain is set properly, and also check that the ground cable has a really good connection to the chassis.
Ronald Reagan (1986)
oh ok yeh il upgrade wire n check ground, the gain is set right.
This sounds more like a problem with the amps going into protection because of either heat, over current, or short circuit. You say the amp stays on. Obviously a light on the amp is telling you this. What colour is the light and also is there another light on the amp somewhere. A lot of amplifiers have a green light telling you its on and also have a red light that comes on when the amp goes into protection mode. It could be a single light that changes color or 2 seperate lights. You need to tell me if the light changes colour or turns off and the red protection light comes on.
It is definitely not a good idea and cheaper to upgrade to a heavy duty battery than add a second battery.
The subs power draw lets say from a 13.8 volt supply would draw 86.9 amps of current so in theory the 8 ga power wire will start to burn. It technically can supply up to 75 amps of current. But this current measurement is dividing 1200 watts peak music power of both the subs by the voltage. The subs power rating is the amount of power it can handle before the voice coil starts to burn so it wont be drawing that many amps of current. Even measuring the RMS power ( root means square ) which is the effective or working power the sub generates at a 12 volt supply is 70.6 amps. Even at 11.5 volts which is generally the point at which an amp shuts down is 73.7 amps which your 8 gauge power wire can still supply.
This is assuming the amplifier can supply the amount of power required. Having said that upgrading to 4gauge is strongly recommended. It can supply up to 150 amps of current from a 5 metre length.
Its unlikely that the voltage drop caused by the battery being worn or alternator wearing out or voltage drop of the small power wire causing the amp to shut down and having to turn the unit off and back on again for the subs to output again. But it may be the case so easiest and cheapest way to solve the problem is replace the fuse at the battery with an 80 amp rating even if it does already have one. Fuses wear out. If problem persist then upgrade to 4 gauge power and earth. Make sure it is a solid connection to bare metal from the amps earth terminal to where you connect it to the body of the vehicle. If problem persists, load test the battery at an auto electrician's workshop. They may quickly do it for free if you ask nicely. They will probably tell you the battery is worn or under charged. They may tell you to put a battery charger on it for 12-24 hours or replace it. You dont need to upgrade to a heavy duty battery. An optima yellow top would cost around 300 but this may not be the cause of your problem. Just buy a normal battery for around 80 dollars. If problem persists I would then take it to a specialised car audio shop. They have other amps and subs to use with your system to find out if the problem is in the product or wiring.
Its impossible to tell why the problem is occuring but a process of elimination is needed. The first parts you can do your self and then get it professionally tested.
thanks mate, yeh first thing il do is change my fuse, upgrade the wiring. and let you know how i go.
(il check to see what happens with the light's on the amp, and see if they change colour)
until then i wont play it high or not much at all, dont wanna risk any damage.
i dont think the problem lies in the power cable..
i think its the earth.. btw which amp you running... im pretty sure it will not be drawing more then 50 amps. (~500wRMS)
it may say MAX 800watts on it.. but then your looking at RMS
either way.. check to make sure the earth is done properly..
i find putting a self tapper though the cable itself and into the chassis is a really good earth (keep the original terminal there)
if you want to upgrade your wiring, go down to jaycar/jb/autobarn and just buy the 4GA by the metre.
To Luke0011 about the lighting on the amp, By the way all i have a kenwood 1800watt mono block, um it has to lights on it a blue light to says it on, and a red light when music playing.
when the subs cut out again i took a look at the amp and blue light stil on but red light was off.
yeh its getting bad now everytime i turn it up for abit it'll cut out. so i dunt play it anymore, imma check ground on weekend n probly buy myself 4g .
it feels lik the system it drawing more power then what the alternater can make lol since its cutting out while driving.
The alternator is putting out about 80amps (I think for your model) which at 14v means about 1120 watts of power. And your system wouldn't use close to that continuously. And then the battery can supply hundreds of amps (think starter motor) on demand. So your electrical system (assuming all in good working order) can easily keep up.
I would check those cables first.
so your amp is putting out...
500 Watts RMSx1 @4 ohm (20-200Hz, 0.5%THD)
900 Watts RMSx1 @2 ohm (100Hz, 1.0%THD)
900 Watts RMSx1 @1 ohm (100Hz, 1.1%THD)
you will deff need 4GA to run this system
it may be cutting out because it does not have enough power.
otherwise check the wires going to the sub and see if there is a short anywhere.
ok, i havnt put 4g in yet plannin this weekend 2 do it, but today wen i started car the bat light and air bag light was on, wouldnt turn off, so i took it to my merchinc and he messured my bat, and said my alternater is putting out to much power to bat, on the scale it goes up to 16volts, the needle went way over!! , lol, so we changed (i forgot what it was on the alternater sum swith thing) and yeh checked it again and it was fine this time, maby this was the problem all along.. i duno ..even so (changing to a 4g still is a must!)
il drive 2moro with music up see if it cuts out again. i think it cut out on the way home i duno buh il check 2moro ..
16volt is a bit high for most amps.
You should be right now, but still put that 4guage in
ok, its still cutting out, like cant have it on high for even 1min.. so i took it to autobarn today, checked it out. the problem is the ground. il have to fix the ground, really sand back the paint and make a good conection. That will fix my problem, but wil need pretty soon a new bat, my bat is only putting out 75 sumthing i forgot. he told me to look at the number get another bat, minium putting out 95. Also wiring 4g.
This all should fix my problemil keep yous posted on how i go. thanks for the comments everybody
Wha?? 75?? The only thing you battery should be putting out is about ~12-12.8v, or up to 14.4v when the car is running.
Are you actually having any problems with the battery? Does your car crank over quickly? Have you checked the water level in the battery lately?
on the bat it says RC 75... he said get a bat thats RC 95 or more
if ur stil not sure i can put up a pic. take a look on ur bat it shud say sumthing like that 2.
also, i fixed up my ground, sanded it back and reconected it. Atm its working pretty good. So that was the main problem.
OK OK I get it,
Yeah cheapy battery generally have a lower RC while better (not necessarily more expensive) batterys have higher, this is what my battery looks like (not my actual battery, just same type, warning large picture) http://www.quintonet.com/qev1/beginnings/IMG_4645.JPG . So I recommend a D34 as a good battery, but any good brand battery will work good. But keep in mind this will not affect the performance of you sound system. As long as you are only using the system with the engine on.What is Reserve Capacity?
Reserve capacity is the time in minutes that a new, fully charged battery will deliver 25 amperes at 80 degrees farenheit and maintain a terminal voltage equal to, or greater than, 1.75 volts per cell. This rating represents the time the battery will continue to operate essential accessories if the alternator or generator of a vehicle fails.
Put another way, reserve capacity is a battery's ability to sustain a minimum vehicle electrical load in the event of a charging system failure. Under the worst conditions (winter driving at night), this minimum could require current for ignition, low beam head lamps, windshield wipers, and defroster while driving at low speeds.
Yeah bad grounds can cause all sorts of headaches, glad you got that fixed.
hey, haven't been on this thread in awhile, but problem was my ground, a temporary fix, I screwed some screws into the wire straight to the body of the car.which made better connection for ground and worked like a charm, but I finally upgraded my battery , and upgraded my wiring to 4Guage. Did that this morning and screwed in couple screws str8 through the wire into body just incase, and for better conection
(found 4Guage wire with ground for $50 at JB, so expensive everywhere else.
