Results 1 to 3 of 3
Thread: Steering wheel volume control
    VYSS Crewman/ VX Berlina/ FG XR6T work car
    Jul 2005
    Default Steering wheel volume control
    The volume controls on the steering wheel of my VY SS Crewman are playing up. The 'down' button is increasing the volume as is the 'Up' button. Any suggestions?
    1992 VP Executive
    Jul 2009
    Take apart the volume module if you can on the steering wheel.
    Check for a short or loose cable that may be running the electrical signal down the wrong wire.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by ringfeder3 View Post
    This is the most common fault with VY's. You can pull them apart and get them re-soldered or something, but I just got hold of some "new" second hand ones and touch wood, they've been fine. You'll need to follow the How-to for removal of VY/VZ steering wheel to the letter, so you don't get an air bag code. You'll just have to go as far as removal of airbag and a set of new buttons will screw back into place, route the wiring correctly and plug them in. They are probably dear from Holden, but of you're lucky like me, good second hand ones may be out there. Or you could go the soldering method but I know jack all on that one.
  1. vz holden adventra steering wheel volume control
    By fourfive in forum Car Audio
    Last Post: 26-02-2012, 09:41 PM
  2. How to fix steering volume control
    By DeveloperChris in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-04-2009, 08:15 PM
  3. VY Steering wheel Volume buttons fuxxored
    By bradrogers in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2007, 12:36 AM
  4. Steering Wheel Volume up button
    By jordanaki in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-10-2007, 01:06 AM
  5. steering wheel volume control issues
    By letemlaf in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-09-2007, 10:20 AM
