hi guys i have an issue with the speakers not working in my rear doors in my vt. the wires are broken somewhere along the line, i have run new wires for them but im not sure how to get them into the back doors, i see the plastic/rubber tube they run thru but dont know how to get my new wires into them. i have unbloted everything and found the plug in there but im unsure as to what to do from there.
any ideas?
cheers SS SLUG.
hi mate, what you need is to get a sturdy length of wire or cut up a coat hanger, get your new speaker wire and wrap about 50mm of electrical tape around both of them at one end.
thread the wire through the door grommet/rubber tube and once youve got enough through the other side, remove the tape, then pull the speaker wire through.
may take a bit of fiddling but be patient.
new doors looms are $26 each from holden... pretty common problem, the power windows will stop working soon too....
Thanks heaps guys
will be sure to let you know how go tomorrow![]()
