Results 1 to 3 of 3
Thread: Amp keeps cutting out with engine on
    VZ Exec
    Aug 2010
    Default Amp keeps cutting out with engine on
    Hey guys,
    I have a cheap 4 ch powervox (it was cheap I only bought it untill I can afford a better one) amp running my from speakers. It is mounted under my passenger seat. It keeps cutting out, the problem is it works when on acc power but it cuts out when I turn the engine on. I thought this was a grounding issue, so I tried grounding it directly to the battery, and the same problem is happening.
    It might be the amp but Im not entirely sure what the problem is.
    Thanks on advance
    Jack
    vt s pack
    Oct 2010
    brisbane
    your car drops battery volts when using air con,
    what size wiring you using??
    cap even maybe?? lol
    VX lumina
    Jul 2008
    SE Melb
    put a multi meter over the remote cable as you have the engine off.. and see if the current drops down when the amp drops.
    could also be amp is overheating...
    could also be car regulator is not working properly.
  1. Engine cutting in and out..
    By jason75 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2009, 06:35 PM
  2. Engine cutting out!
    By bertusmcspurtus in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-02-2007, 03:11 PM
  3. Engine Cutting Out
    By gone_nutz13 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2006, 01:38 PM
  4. Engine Keeps cutting out
    By tommo824 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 06:03 PM
  5. Cutting through engine bay?
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-12-2005, 04:02 PM
