Results 1 to 14 of 14
Thread: Amp/Sub question?
    Hibbo_Jnr's Avatar
    Hibbo_Jnr is offline Livin' the minute...
    1999 VT S-Pack
    Oct 2010
    East Gippsland
    Default Amp/Sub question?
    I've got two subs sitting in my room both in box. 1 15 inch sub and a box with 2 10 inch subs in it. Which would be better suited to my VT? Also for the 2 tens will i need two amps?
    VX acclaim S2
    Oct 2009
    i would run with the twin 10", and know, youl either need a monoblock, or depending or how you wire it, a 2 channel amp
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Depends on the subs, depends on what music you like, depends if you like 'punchy bass' or 'rolling' bass, depends on what amps you got, depends on the impedance of the subs.
    We are going to need more info than this to help you. Just start with the model numbers of the subs and any amps you have to run it/them.
    Ronald Reagan (1986)
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    What music do you listen to?
    An what model numbers are the subs?
    Hibbo_Jnr's Avatar
    1999 VT S-Pack
    Oct 2010
    East Gippsland
    Prefer to listen to rolly type bass. Music like the dirty beats volumes. Unsure on the model numbers as i can't find on internet and all thats on the box is 'high quality subwoofer'
    VP Berlina LX 92
    Jun 2010
    Wodonga, Victoria
    hmm you will need to get the subs out and look at the sticker/label on the underside of the sub just so we can get a clearer picture on what advice to give
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Post of pic of em, sumone may be able to pick what they are
    ________________________________________
    Hibbo_Jnr's Avatar
    1999 VT S-Pack
    Oct 2010
    East Gippsland
    Pulled one out and wrote down what was on the back of the subs.
    RMS: 225 watt
    MAX: 450 watt
    10 inch subwoofer CW2198
    Does this help guys?
    This is the woofer
    http://www.jaycar.com.au/productView...e&form=KEYWORD
    Philthy's Avatar
    Aug 2005
    They will be pretty rubbish for deep bass. What is the 15" one?
    Hibbo_Jnr's Avatar
    1999 VT S-Pack
    Oct 2010
    East Gippsland
    Haven't tried it yet. Heres the 15'' http://www.crazysales.com.au/kingwoo...ofer_p120.html
    I'll only be using these subs until i i decided to upgrade my audio in the car.
    VX Berlina
    Apr 2007
    LOL at higher 'output maximum' than max power, whatever the hell output maximum is. Maybe its a perpetual sub or something.
    So what you have here is two 10" subs that are suited for tight bass and not deep bass, and one 15" paperweight.
    As for amps you need an amp that makes 450wrms at 4-ohms, to drive those two 10" subs. If your on a tight budget than this will do it, Shopping Secure - Car Audio Specialists - Ground Zero Iridium GZIA 2230HPX .
    Hibbo_Jnr's Avatar
    1999 VT S-Pack
    Oct 2010
    East Gippsland
    Quote Originally Posted by acarmody View Post
    Cheers mate. I'll cruise around and look for some other amp also. How many channels should i be looking for?
    VX Berlina
    Apr 2007
    A single channel amp is always best for running subs, but your problem is that you want the power at 4-ohms, whereas most mono-amps make their most power at 1 or 2-ohms.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    You know those paper cone woofers aren't too bad in a 3 way HT setup on a budget, but they are not suitable for car audio use due to the impedance level. As said above at best you could wire them together to get a 4 ohm load, but even then you won't find a mono block amp that would produce the sort of power levels you are after @ 4ohm.
    Maybe you could sell what you have and try to find something else on a budget.
    But really unless your going to spend decent amounts of money on a sub in a car this sized, you'd be better of with a decent set of full range speakers instead...
  1. [NSW] v6 cam question...
    By 1991_vc_v6 in forum General
    Last Post: 17-03-2010, 07:46 PM
  2. LPG or not to LPG....that is the question!
    By FNQWagonMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2008, 10:54 PM
  3. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  4. VN V8 Question
    By UNSAFE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 05:46 PM
