Results 1 to 4 of 4
Thread: Amp blows a fuse as soon as car is turned on :(
    VS Spac 5spd and r32 skyline 5spd turbo
    Sep 2010
    Mount Gambier
    Angry Amp blows a fuse as soon as car is turned on :(
    So i was driving along with the sub on which is a 2000 wat earthquake sub and amp anyways it cut out and it blew both fuses at the back of the amp but not the main fuse near the battery. so first thing i tried was get two new fuses but as soon as i put the fuses in they died again ?. is there anything i can try and do to diagnose the problem. i rewired the earth as it was dodgy but i havent bothered putting new fuses in as ther about five bucks a pop (takes two at the back). i have heard disconnecting the sub from the amp and turning it on. if the amp still blows the fuses then the amp is the problem. if it doesnt the sub is. is this true ?? any other suggestions ? the sound is so plain with out a sub i hate it lol
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    If the earth was 'dodgy' it may well have been causing the fuses to blow, make sure the positive wire is also not earthing out anywhere. and yes test without sub connected, make sure sub is wired correctly and no loose wires earthing out on the speaker basket.
    Power is measured in DECIBEL
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Disconnect the subwoofer wires and the RCA cables, re-do the earth using an existing bolt in the car (like the rear seatbelt bolts) by removing the bolt and sanding back the area to bare metal, then attaching your earth cable to the bolt and tighten it back up. If you like you can add a squirt of paint over the top to stop rust and resistance etc.
    Once thats done make sure the ignition is OFF and insert a fuse, if it blows then you have a faulty amp. Its possible the "dodgy" earth could have caused problems internally.
    150db in a commodore =
    VL Wagon
    Aug 2010
    Adelaide, Australia
    the bad earth most likely killed the amp.
    save your money on the fuses, and put it towards a new amp, or getting your old one repaired.
  1. VT cigarette lighter fuse blows
    By willkill41 in forum Electrical Wiring / Questions
    Last Post: 25-01-2010, 02:09 PM
  2. when put into reverse blows fuse
    By blackwagon in forum Electrical Wiring / Questions
    Last Post: 31-01-2009, 08:04 PM
  3. VS V6 blows fuse cuts engine...
    By vshilux in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2008, 07:34 PM
  4. VC Commodore Blows Instrument Fuse??
    By vk4akp in forum Electrical Wiring / Questions
    Last Post: 01-12-2008, 07:55 PM
  5. VT Horn Fuse Blows
    By brett 46 in forum Electrical Wiring / Questions
    Last Post: 28-03-2007, 06:54 PM
