Results 1 to 12 of 12
Thread: 3 4gauge wires in a vn
    VN Commodore
    Sep 2010
    Orange N.S.W
    Default 3 4gauge wires in a vn
    im running 3 4gauge power wires in my vn commodore its an automatic where should i run them or should i drill a hole in the fire wall any help please thanks
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    Run a single length of 0awg through where the clutch would be , use a distribution block in the boot and alot easier to mount 1 fuse in the engine bay , what makes you believe you need 3 runs of 4awg ?
    Do you amplifiers have 300amps of current draw ?
    Right click save as . .
    VN Commodore
    Sep 2010
    Orange N.S.W
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    VN Commodore
    Sep 2010
    Orange N.S.W
    VN Commodore
    Sep 2010
    Orange N.S.W
    sorry im kinda new at putting in more den1 amps im puttin in 3 rockford fostage amps monoblocks
    2x 12" subs same brand
    1x10" sub
    set of 6x9 in the pacel shelf
    2x6.5" in the front doors in a custom fiberglass encloser
    i want it to be a weekend warrior in comp
    but its my daily driver
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Ok first, bugger off the 10" sub, don't mix sub sizes, would probably even hurt your score in a comp, or a best just take power away from the two 12" which will be the ones making the score.
    Also unless your running the 6x9" on a HPF, than I would bugger them off too. 6x9" are basically 8" woofers, so again not needed with the 12"s there.
    Also you would be better off just running a single 0-gauge wire from the battery to the boot and using a distribution block from there.
    Ronald Reagan (1986)
    VN Commodore
    Sep 2010
    Orange N.S.W
    ok thank you that helps alot
    the only reason im using 3 runs of 4gauge is becasue i have been given 20 metres of the stuff and its real good wire
    VX Berlina
    Apr 2007
    Well yeah in that case go for it. If you have it than use it.
    VN Commodore
    Sep 2010
    Orange N.S.W
    yea so just put it though the cutch cable hole or can u recomend another hole
    VX Berlina
    Apr 2007
    Clutch hole is best. Big hole and easy enough to get to.
    VL Wagon
    Aug 2010
    Adelaide, Australia
    Quote Originally Posted by KAL SPL View Post
    Ermm what ?
    I was under the impression this was an English speaking forum too!
  1. VR BUICK COIL PACK WIRES + and - which wires???
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:32 PM
  2. Where to run the wires for a amp and sub in a vs?
    By vs_commy5506 in forum Car Audio
    Last Post: 25-07-2009, 06:23 PM
  3. where to run the wires
    By HCVP in forum Car Audio
    Last Post: 06-07-2009, 11:09 PM
  4. what r these wires
    By Matt_vp in forum Electrical Wiring / Questions
    Last Post: 17-01-2007, 10:59 AM
  5. Amp Wires?
    By todds_vt_2005 in forum Car Audio
    Last Post: 19-03-2006, 11:46 PM
