Results 1 to 6 of 6
Thread: what amp to use
    VZ SV6
    Jul 2010
    Mandurah
    Default what amp to use
    ok guys been reserching on amps to use to power two type r subs rated 500rms each
    i can use either the alpine mrp m1000 wich is 1000rms at 2ohm
    or the soundstream lw1.1700 wich is 1200rms at 2 ohm but is bit more expensive
    any adivce and why ones is better would be great
    IF YOU WANNA REV IT CHEV IT
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    VZ SV6
    Jul 2010
    Mandurah
    dual voiciol and it say 2ohm on the subs so im assumign dual 2 ohm
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    Do you lready have the subs , if not get the D4 version and run the soundstream as it has a 1 ohm rating @1700rms
    By a little more in price do you mean $500 as opposed to $800 , thats if Ebay is anything to go by !
    The Alpine lowest rating is 2 ohm so ideally its best suited to the subs if you already have the D2s , buying the SS is no worse off but your basically spending an extra $300 for no more benefit other than you could add 2 more D2s later and still run all 4 safely and correctly loaded.
    Right click save as . .
    VZ SV6
    Jul 2010
    Mandurah
    yes ive got the duel 2ohm ones in my room jsut need an amp to power them wat about 2 of the alpine ones vs one wat would be better the part no mrp m100
    VX lumina
    Jul 2008
    SE Melb
    why stop ot 1000wrms..
    using that alpine would mean running it 100% which is not really recommended.
    those amps have a a mark 2/3 of the way which say nom.
    shameless plug
    im selling a mrp-m2000 if you want cheap power...
    mines brand new.. and still in original box.
    1500wrms @4ohms
    2000wrms @2ohms
    2274wrms @2ohms on birth cert.
    $650
    i think 2000 watts would be good to run them as if you set it to a safe 2/3 you will be running about 1500watts when fully cranked..
