ive got sum reattle going on in my boot with sum smaller 12'si have and want to remove it jsut asking were have u guys found rattle to come from so i can start looking
IF YOU WANNA REV IT CHEV IT
I also have a 12 si in my boot. Bumps hard. Rattles like a biatch. Made rego plate loose too.
i put dynamat behind the number plate.. well on it but at the back.. did not rattle one bit with it in.. then i deveoloped a rattle on the roof trim (dodgy repair by a panel beater after my car was repaired and should of been written off)
every car is different for rattle..
i actually jumped in the boot and turned the sub on low and looked for rattle... some of it came from the parcel shelf metal hitting the plastic parcel shelf cover.
using some foam sheet i cut it to size and lined the back with it.. stopped it form rattling.. ..
