Results 1 to 5 of 5
Thread: VE Head unit
    07 VE Sv6 ute
    Nov 2010
    Sunny coast
    Default VE Head unit
    hey guys.
    i got my ve and i heard there was going to be new dash units that can be installed so you can install after market head units and dvd players.
    just wondering if anyone knows anything about it or if they will bring one out.
    cheers tom
    VE SV6 Commodore
    Sep 2009
    Perth, WA
    There is a million topics on this, please search the forum before posting
    VE Berlina Sport Wagon 3.6 4SP Auto
    Dec 2010
    Lavington NSW
    You might have to upgrade your dash to make it work, so if you want all the gadgits, DVD GPS etc just bolt in a Calais unit...
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by mmarch1 View Post
    You can't just grab a higher spec unit and plug and play. The units require programming changes to the car, the unit, and changes to the climate control / AC system. Very expensive, worth more than the replacement unit itself. I only found this out after making basically the same enquiries as the OP.
    TTT90 - Right now the only option you have as far as replacing the source entirely, is to fit a single DIN unit under the heater controls. Nothing has been released (to my knowledge) that allows easy install of any aftermarket sources. The Blaupunkt unit is just too integrated, and controls more than just audio in some of the upper spec models, most likely it will never happen.
    Your on your own with a very complicated wiring harness , and some very time consuming and expensive fascia modifying if your dead keen on anything beyond a single DIN install....
    mi04se1's Avatar
    mi04se1 is offline need for speed
    Pontiac G8GT
    Nov 2009
    White Lake, MI
    Here is an alternative Folcik Engineering & Design, LLC..
    2009 Liquid Red G8GT
    4 door mafia
    93 octane VMS ecm/tcm tune
  1. New pioneer head unit - problems with old stock unit
    By thejdizzle015 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-07-2010, 05:19 PM
  2. Head unit running off head lights?
    By billyjim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2010, 04:44 PM
  3. head lights cut out head unit.
    By Silver_VS_II in forum Electrical Wiring / Questions
    Last Post: 03-05-2010, 11:39 AM
  4. Replacing VT head unit with BT ipod unit
    By nickbedford in forum Car Audio
    Last Post: 23-06-2009, 03:00 PM
  5. VZ head unit into VT?
    By sully87 in forum Car Audio
    Last Post: 05-04-2009, 08:56 PM
