Results 1 to 7 of 7
Thread: ve stereo crazyy
    VZ SV6
    Jul 2008
    Default ve stereo crazyy
    just bought a new ve ute and the stereo whilst isnt too bad in my opinion.. could be a little better.
    so i had a pair of JL audio vr600 components and i decided to wire up the speakers ( not crossovers and tweeters).
    i only installed one side to hear the comparison, but only to find out the JL speakers weren't sounding as near as good as the standard ones. They lacked bass, and distorted at a far lower volume.
    Would this have anything to do with not connecting the crossovers? Also i only connected them with some cheap wires from the 2 dollar store,, so i was curious do different wires really effect sound quality.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    Speakers realy need an amp to power them propperly so they can work their full range.
    Crossover i believe just limit frequency range for tweeters.
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Speaker wire can play a part, but generally unless the wire is of insufficient gauge, then audible differences would be negligible. Do you check that you hadn't wired them out of phase?
    Otherwise, the distortion could be caused by the head unit's in built amplifier being driven to the point of clipping.
    They may not be as loud at any given point due to a lower sensitivity rating compared to the original factory speakers. I'm not familiar with the factory ones that are in there, so i couldn't tell you if they are higher than the 89db of the 600's.
    For brief testing purposes it isn't nessacary to wire up the crossover that comes with them, because the standard crossover fitted to the Blaupunkt unit will still be doing the same job, unless you disconnected the factory one, in which case the midbass / midrange driver would be tying to produce fq's that are higher than it's response range.
    VZ SV6
    Jul 2008
    Mar 2009
    Cairns White Rock
    VZ SV6
    Jul 2008
    oh nah thats wired up properly 100%.
    now it seems the right speaker is putting out less bass compared to the left.
    anyone with a ve ute can you please confirm that they are exactly the same so i know i stuffed up =]
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    No leaks around the speaker, could contribute to less bass out of one speaker
    ________________________________________
  1. VE stereo
    By astroham in forum ASR Audio & Electronics
    Last Post: 14-07-2010, 08:46 AM
  2. Stereo
    By ryan23 in forum Car Audio
    Last Post: 24-03-2010, 07:22 PM
  3. vk stereo
    By young vk boi in forum Car Audio
    Last Post: 22-04-2007, 05:22 PM
  4. VK stereo
    By 85berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-07-2006, 10:30 PM
  5. VR stereo
    By twinkle in forum Car Audio
    Last Post: 27-06-2005, 08:48 PM
