Results 1 to 4 of 4
Thread: Subs and amp randomly stopped working??
    vr executive
    Nov 2008
    Default Subs and amp randomly stopped working??
    hey guys
    my x2 12 inch subs and clarion amp stoped working today randomly.
    the light on my amp doesnt come on when i put a cd on.
    ive checked all the wires going to the amp and the subs and there all in place.
    any ideas?
    cheers
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    If the amp isn't blown, then it's one of 3 things.
    1 - Ground wire.
    2- Power wire, also check inline fuse
    3- Trigger wire
    They are the only things respnsible for an amp powering on.
    (EDIT) Also amp's main fuses as mentioned below by Stone, i forgot to mention them.
    VH SL/X Wagon
    Feb 2009
    When you say it doesn't work when you put a CD in, does it work when you have it on radio? A common mistake people make when installing is to use the head units aerial trigger wire instead of amp trigger wire, which does the same thing as the amp trigger wire but only when the head unit is set to radio.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Another thing to check is the fuses on the amp and the fuse on the main power wire, it should be near the battery in the engine bay.
  1. Subs stopped working??
    By randomhero365 in forum Car Audio
    Last Post: 19-02-2009, 07:58 PM
  2. Speed stopped working
    By mxlegend99 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2008, 06:32 PM
  3. My key stopped working.. :(
    By Howks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2008, 11:52 PM
  4. Tacho stopped working.....
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2008, 08:33 PM
  5. VN Air Con randomly stops working?
    By DavidPartay in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 06:29 AM
