Results 1 to 5 of 5
Thread: Help with my amp/sub set up
    dumpedvs's Avatar
    dumpedvs is offline sheppa8
    Vx S
    Mar 2010
    Default Help with my amp/sub set up
    Hey guys, I have 2 10" Single coil 4ohm subs that are 250rms each, and a Kenwood KAC-9104D amp.
    Simply is this an alright set up, because i got the subs for free and the amp for $160
    What do you think? Should i wire it at 2ohm?
    Thanks, Shep
    I reject your reality and substitute my own.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Yep, wire them down to 2-ohms, just adjust your gains appropriately so you don't blow the subs up.
    Plenty of headroom there, amp will run nice and cool.
    Ronald Reagan (1986)
    dumpedvs's Avatar
    Vx S
    Mar 2010
    Okay thanks for the info.
    what should i set the gains at? any rough idea?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Put simply the gain control is just a way of controlling how loud the amplifier is when controlled from a seperate source. If the gains are set higher, then the amplifier will be louder at a lower volume through the source you are using to control it. Turning the gain down lower will require the volume control to be turned up higher at the other end.
    It has nothing to do with power output from the amplifier, the amp puts out the same amount of power regardless of where the gain is set at.
    If you have the gain set so that you can reach a higher level of volume on the head unit, then you get better volume adjustment as the increase is made in smaller incriments allowing you to be more precise.
    Just set the volume at a reasonably high level on your head unit ( if it goes form 0-40 then say about 30-35) Begin with the gain at it's minuimum settings. Very slowly adjust the gain, until you either are aware of the subwoofers limits, there is any audible distortion.
    If you have a seperate amplifier that runs your in-car speakers, then you need to repeat the same process. Always set your gains at the same volume on the head unit so that your previous adjustments for any amp remain the same.
    dumpedvs's Avatar
    Vx S
    Mar 2010
    Okay, thanks alot HCVP. Good help
LinkBacks (?)
  1. 12-12-2010, 01:01 PM
