Results 1 to 3 of 3
Thread: Line out converter on ve
    ve omega
    Dec 2009
    brisbane qld
    Default Line out converter on ve
    hey guys i need help setting up a line out converter on the ve,
    ive done a bit with car audio but dont waanna do it wrong as its for a mate.
    i was hoping to get a quick step by step instructions if possible?
    any help much appreciated,
    cheers
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Mate they basically all work the same. They have an input, and an output.
    The input is for your speaker wires. Depending on whether you have a 2, or 4 channel LOC, will determine whether you use the signal from only the front speakers, or both the front and rear.
    Locate you speaker wire. Now i haven't worked on a VE yet, so i can't tell you where the crossovers are located.
    The positive and negative from each speaker wire which now come from the head unit are connected to the LOC's input. The output is for your RCA leads to connected and run to the amplifier.
    Run your new speaker wire form the amp back along it's original path to be re-connected.
    ve omega
    Dec 2009
    brisbane qld
    cheers mate that made it alot more understandable
    cheers
  1. VE amp install and line output converter
    By dav0j in forum Car Audio
    Last Post: 31-08-2010, 04:14 PM
  2. VE amp install + line output converter
    Last Post: 10-03-2010, 06:32 PM
  3. Line Out Converter (LOC) HELPPP!!!
    By kizza50 in forum Car Audio
    Last Post: 28-10-2009, 11:18 PM
  4. vz - line converter -> amp -> sub help
    By nikolas in forum Car Audio
    Last Post: 31-12-2008, 11:16 AM
  5. Exact VE model line up, Colours, Trim options, And HSV Line up. THE GTS IS BACK!!!
    By blackahcdx in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-07-2006, 10:18 PM
