hey all, i just thought id make a thread for all those VR/VS owners who has a nice system installed in their car and would like to show it off to the world.
So All VR/VS owners, please upload your pics and show us your stuff
this is an install into one of my mates VRs.....a lot of time, a lot of glue....lot of carpet...and a lot of blue...
we need pics like that but showing on steps how its done !!
Indeed, i would definatly apreciate a tutorial with pics on tricking out your boot with subs, amps and crossovers etc.
PURE sex! every system needs to start some where!
anyways, finally got some time to take some pics of my boot n the underside of my parcel shelf (boot lining and parcel shelf are getting retrimmed).
the sub amp isnt wired up at this point in time because im waiting on my custom sub box (which is taking ages to get to fit perfectly in the middle seat)
heres some details about how its done for those of you that want some...
both amps are mounted to 15mm MDF which is mounted to the parcel shelf (you can see the screws through to the parcel shelf in the 'under parcel shelf' photo) these screws are going to be chopped and welded to the parcel shelf for added security) the screws holding the amps to the boards are also going to be chopped and the heads filled so they cannot be unscrewed. after which im going to goto clark rubber and get a nice chunky bit of rubber made to glue between the MDF and the parcel shelf (to hide the top part of the MDF from view)
ive got all my speaker wire running through the central circular hole in the parcel shelf to the amp
my rca cables run down the same side as my front speaker wire but the rca cables are run through the back of the rear seat rather than the central hole.
my power and remote cables run down the other side of the car, are the cables are tucked through the rails at the back of the rear seat to keep them lifted, and the earth cable is earthed to a factory made hole up the back of the boot just under the rear side window.
also thought id attach a photo of where ive got my tweeters placed in the front.
im slowly getting there, im hopefully getting a mp3 headunit and some new rear speakers (i want the extra 15 watts of power in the rear) and the sub amp will be wired up as soon as the box is perfected.
