Results 1 to 11 of 11
Thread: Sub box fell apart?
    VX Berlina LS1
    Apr 2007
    Default Sub box fell apart?
    Ok well i got my new deck in and started listening to tunes again finally!
    The other day i thought my sub was making weird ab normal sounds. Like it wasnt hitting the notes the way it was suppose to. I turned the bass to -6 and bass control to 0 on my amp. When i turned the volume up to a certain point it would make the same noise.
    Upon further investigation i found that the top of the box has come loose and when the bass hits hard it just rattles it continiously.
    Should i get a new box or just glue this one down?
    Cheers Dan
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Well that most likely happened because it was built poorly from the begining.
    Was it a pre-fabricated one, or something you built yourself?
    What sub / amp are we talking about to get a better idea on things...
    VX Berlina LS1
    Apr 2007
    It's a pre fab box. Its housing a single Kicker L7 12" the amp im running is the kicker kx1200.1. Im also thinking of running a dual setup and gettin a new amp
    Mar 2009
    Cairns White Rock
    Well a pre fab wasn't a good idea form the start. Most are made too thin (16mm sometimes less) and are usually just glued together with no screws, internal bracing or anything.
    You could repair it, and even modify it, but i wouldn't bother, unless your not really fussy about your subs performance. I'd build a new box that is closer to the specs of the sub, that way not only will it last, but it will help you to get the most out of your sub aswell.
    I guess it comes down to what you want, how much you want to spend and how far your willing to go, and of course your DIY skills , available tools ect...
    VX Berlina LS1
    Apr 2007
    Yeah i was thinking of getting a built box. I was so frustrated that my music sounded so shitty. Il just look at gettin a dual setup for 2 12"s built and an ampp to suit.
    Cheers for your help
    Mar 2009
    Cairns White Rock
    The L7's IMO are better suited to ported enlclosures if your building your own.
    VX Berlina LS1
    Apr 2007
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    That's a pretty beefy amp for just one L7.
    Earlier this year I built a couple of ported SPL boxes for my L7s, any bigger and you won't be able to get them in.
    If you want about halfway down this page I start building the boxes, dimensions are in there somewhere too, Advice on building some SPL sub boxes
    Ronald Reagan (1986)
    vt commodore
    May 2010
    whats the best score you did with that box i think you would be louder if the box was smaller seems to big to me
    ssnw vt commodore sedan
    loudest commodore in aus
    official pb score : 154.2db
    unofficial pb score:154.8db
    VX Berlina
    Apr 2007
    Never ended up getting a reading, the comp was called off because retards didn't pre-register, they all just rocked up on the day.
    But as soon as my H/U is fixed and another comp comes up, than I will be there.
    And they are only 2.5cu.ft each. They don't go all the way back because the middle seatbelt bolt sticks down and stops them.
    VX Berlina LS1
    Apr 2007
    Yeah the amp is pretty beefy i think thats why the box broke lol. Geez that is a big bos imo i cant wait to get my dual setup
  1. vz commodore ecu fell out what to do
    By vz23kq in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-10-2010, 09:04 AM
  2. Vz commodore bcu fell out how to put back?
    Last Post: 07-10-2010, 01:47 PM
  3. VN SS door strip fell off
    By creesy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2010, 10:28 PM
  4. Supercharger belt fell off. What the?!?!
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2007, 02:59 PM
  5. P plate fell off, Need advice
    By flat6 in forum The Pub
    Last Post: 29-03-2006, 07:47 PM
