Results 1 to 7 of 7
Thread: vz sv6 stereo upgrade
    VZ sv6
    Dec 2010
    melb
    Default vz sv6 stereo upgrade
    Hey guys im in need of some help, im upgradeing my stereo in my vz starting off with the rca mod on my standard headunit, but im not sure what i should do about speakers...i wanna run front 6.5 components and rear speakers but should i run 6inch in the door or 6x9s in the shelf? on a amp or headunit?
    ill be running a kicker 12 inch sub in boot off a kicker amp
    any help would be great
    thanks
    Benny
    VZ Executive
    Nov 2008
    how about instead of buying rear speakers you just get better front speakers.
    rear speakers are only for passengers and heck if they complain make them buy them
    VZ sv6
    Dec 2010
    melb
    vt commodore
    May 2010
    why dont you try buying soundstream gear my commo with 2 soundstream t5-12 was smacking this guy at the comps that had the same car and was running 2 kicker L7-15''s and we had the same power untill i went bigger
    ssnw vt commodore sedan
    loudest commodore in aus
    official pb score : 154.2db
    unofficial pb score:154.8db
    VZ sv6
    Dec 2010
    melb
    i decided running kicker components in front and 6inch kicker coxials in rear and running them off a 4 channel amp., question is with my headunit mod i only got two sets of rcas but im going to run a 4 channel and mono block amp how do i do this?
    thanks
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    split the rca for the 4 ch amp, so one set of rcas do the 4 channel amp with splitters for them and the other for the sub. only down fall is that you will not have any control of fading except at the amps
    Spoken by a true member of The Committee
    VZ sv6
    Dec 2010
    melb
    thanks mate i thought that was the case, ill just have to tune the speakers from the amp
  1. stereo upgrade
    By taff in forum ASR Audio & Electronics
    Last Post: 19-07-2011, 06:55 PM
  2. VY Ute Stereo upgrade
    By VYUTE in forum Car Audio
    Last Post: 07-05-2011, 02:08 PM
  3. Vy stereo Upgrade Need Help
    By G4orce in forum Car Audio
    Last Post: 25-02-2008, 07:42 PM
  4. 2 din stereo upgrade
    By neobristol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2006, 11:01 PM
  5. VZ SV6 Stereo Upgrade
    By tja_bot in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-10-2006, 04:11 PM
