Results 1 to 9 of 9
Thread: Dynamat Install
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    Default Dynamat Install
    Hi guys,
    i have just purchased some new front spilts and also some dynamat.
    i am just wondering where to put the dynamat, do i put it inside the door, or just where the original plastic stuff that sticks on the door is.
    thanks
    Matt
    Growing Old is Mandatory...Growing Up is Optional!
    My Ride http://forums.justcommodores.com.au/...utive-9c1.html
    VZ sv6
    Dec 2010
    melb
    pretty sure mate take off that plastic crap and cover the door, try fill the empty holes with 3mm mdf
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You put it on the outer skin and the inner skin. But you seal the access holes of the inner skin with 3mm MDF, as mentioned, but you should paint the 3mm MDF with a waterproof paint so it doesn't soak up any water.
    There's a tutorial on the Mobile Electronics Australia forum of how to do it.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    normally thick dynamat on the door skin INSIDE door
    and a thin layer on where the plastic goes but a lot of people will just cover the holesnot the entire thing where the
    clear plastic goes onto as it makes it hard to refit door card!~
    putting it on the skin inside the door stops noise escaping the car
    putting it on the inner part and sealing the door itself makes it like a sub box using the door cavitie itself as a box!~
    Aug 2009
    thanks for the replies guys, i thought it was on the inside mainly, thats going to be a bitch of a job to get it in there!! unfortunately it is going to have to wait over a fortnight as i have work and chrissie stuff...bugger
    VX SS 5.7
    Mar 2009
    North Adelaide
    Thats the deadening on my car. The outer skin was done, Dynaxorb pads behind the speakers, MDF speaker mounts - much more solid than the crappy plastic pods, baffle to seal the service hole at the bottom and dynamat over everything.
    Check out Home
    Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
    Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    Aug 2009
    Langas, what did you do to make the MDF speaker mounts, just take the originals and make them in mdf??? not a bad idea.
    Maybe i need to get some more dynamat, me thinks i may only have enough to do the outside of my doors, dont really want to waste 400buck speakers without doing the job properly, i think i may also have to wait and get the job done properly over a weekend.
    VX SS 5.7
    Mar 2009
    North Adelaide
    Good Move,
    I had clearance issues with my Focals (they are rather deep) so that was the main thing that prompted me to give the stock cups the flick. I basically traced a template out onto some cardboard then cut it out in 18mm MDF.
    On the door skin I did roughly half the top and the whole bottom section, and the whole inner skin (as you can see).
    The best bit...the door now gives an awesome 'thud' when its closed.....like a nice merc or bmw
  1. Dynamat
    By marcdon in forum Car Audio
    Last Post: 24-03-2010, 08:09 PM
  2. Dynamat??
    By Robbo VS3 in forum Car Audio
    Last Post: 09-10-2009, 12:38 AM
  3. WTB Dynamat
    By dawg in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2008, 04:30 PM
  4. Dynamat. 11/10.
    By VNCalais98K in forum Car Audio
    Last Post: 20-02-2007, 08:27 PM
  5. Dynamat
    By 4PLAYN in forum General
    Last Post: 12-09-2006, 09:25 PM
