i am putting a new headunit into my 96 holden barina and i was wondering which wire is the accessories wire and wat colour is or can someone give me a wiring diagram for it
cant help with the wiring diagram however, you can pick up a tester at ya local supercheap etc for only a couple of bucks. It basically looks like a screwdriver with a wire and crocodile clip comin out the top. Use the croc clip to earth it and touch it on each wire with the key switched to accessory, when you get a light turn the key off. If the light goes out then bingo, you have your wire.
i kinda need to know wat colour the wire is
accessories is yellow, 12V is orange with black, earth is black
Your going to need to connect more than acc for the deck to work
Barina will have ISO plugs , best to just get them , saves cutting the wires off and all the pins will match up.
Right click save as . .
