Results 1 to 7 of 7
Thread: Sub Not Working VN
    VN II Berlina
    Apr 2009
    Default Sub Not Working VN
    yesterday my sub magically stopped working and i have no idea why.
    it had been working for a very long time previously and i did the install myself so can't see any reason why it would've stopped??
    Its not because the amp is hot,
    No loose wires or dodgy connections,
    No blown fuses,
    Amp light on (little light saying protection on is lit up basically just showing that the remote wire is connected from the headunit)
    Sub is NOT turned off from the headunit.
    any other ideas on what i can look for?
    for reference its a US-Audio Amp (USA554-220Z) and a 1000 Watt dual voice coil Kenwood sub, if they have some sort of common problem?
    Thanks
    VN II Berlina
    Apr 2009
    anyone got any idea what else i can look for?
    none of the wires are being shorted out, and this morning for about a minute the sub was working, then again back to nothing.
    That was while i was driving
    VX SS 5.7
    Mar 2009
    North Adelaide
    Have you got a multimeter? I'd start by making sure you have a stable voltage at the amp.
    Are there any lights on the amplifier? Is the amplifier turning on when you turn the headunit on?
    Its worthwhile going over your cabling with a fine tooth comb...Its either something fairly simple or a buggered amp!
    Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
    Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    + 1 voltage, check the ground where you are earthing the amp first. normally that is the problem. secondly check the + making sure you are getting 12.0+volts.
    If you are not seeing 12.0volts when checking the ground, scrap some of the paint away back to bare metal. the re-attach your ground wire. this should fix the problem.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Hate to sound like a broken record, but check your earth. If it looks fine, pull it off and try earthing somewhere else. Make sure you sand back the new earth as well
    VN II Berlina
    Apr 2009
    Quote Originally Posted by Philthy View Post
    yepp ive done all these except multimeter checks, and yeh the remote wire is fine because the light on the "protection on" light doesnt go on unless the HU is connected.
    my earth thats ive been using has worked the whole time and i sanded it back when i connected it like you said.
    ill remove it and clean the area and re-attach it since you guys believe thats usally the problem.
    I'll let you know how it goes.
    Thanks
    VN II Berlina
    Apr 2009
    all good working now, just replaced some wires even though they all looked ok, and shes workin now!
    thanks guys
  1. How to tell if a LSD is working
    By red truck in forum General
    Last Post: 13-10-2009, 10:36 AM
  2. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  3. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  4. Fan not working on VN
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2006, 01:20 AM
  5. VK Fan not working
    By Kevin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 04:41 PM
