Results 1 to 8 of 8
Thread: Random subwoofer popping
    VY executive ute s1
    Jan 2009
    Default Random subwoofer popping
    At random times when played at full tilt i get a sharp ''pop'' sound from my subwoofer. Its only occasionally and when played at high bass loads, mainly with rock music
    My setup in
    Pionner shallow 10inch 300rms sub behind a seat in a ute
    Pionner 8400m mono block amp
    Pioneer 3250 dvd headunit
    Now, please take into account im jumping on here asking questions without fiddling with any of the settings. My amp is the same as it came from the box, i havnt changed the EQ on my ipod and i havnt played with the sub or EQ on my headunit since the sub has been put in
    Are there any other reasons why this popping sound may occur?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Who installed the gear?
    Sounds like it could be a loose connection on the amp and / or sub.
    150db in a commodore =
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    It could just be bottoming out, (you did say at full tilt) that might be the noise you are hearing, you might be hearing it easier because the sub is in the cabin.
    Personally I don't reccomend running 10's without sub sonic filters because most don't like to play to low. When you feed a bit of volume into a smaller woofer and you come across a really low fq note through out a song, it can be enough to cause the sub to bottom out.
    Using a test tone CD will let you find the fq response and abiltiies of the sub. Settings your SS filter (if you had one i don't think you do) and you LPF will let them play within their limits all day long.
    VY executive ute s1
    Jan 2009
    My amp doesnt have a SS filter, but it does have a LPF with settings from 40hz to 240hz. Where can i purchases a SS filter from? or do i need a amp with it built in?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I don't know where you can get them in Australia, nor do I know how good they are.
    FMOD (Filter Module) High Pass RCA Level Crossover
    Ronald Reagan (1986)
    VY executive ute s1
    Jan 2009
    yeah, i can get these from a guy in SA but its from like an old turntable player business so i dunno if they work with modern car amps??
    i cheakced connections, it doesnt seem like anythings loose. I stripped back more cover and put more wire in all connections to make it snug, but it still pops. Its not even really when i push it, coz itll start popping, then if i turn it up more it still pops randomly but plays some notes cleanly
    i run a sealed box behind my seat in my ute. Its filled with Dacron (i think its called) should i take this out?
    vx exec
    Dec 2010
    new zealand
    its clearly a amp "clip" problem..if the amp is in bridge mode this can be common if slightly underpowered, and is basically a "square wave" or electric current getting to the speaker..you could try your hi pass filter with a roll off starting around 50hz, with a gentle slope
    while your sub wont produce these freq your amp will.
    Mar 2009
    Cairns White Rock
    Dacron just reduces the rear standing waves, and some say it can make the driver act as though it's in a larger enclosure. A 10'' sealed would use a very small enclosure as it is, the dacron used isn't likely to have any effect on it's volume, and if anything depending on how much you have used you could even add more.
    But no it dosen't having anything to do with your problem. I'm still putting my money on your amp clipping.
    Your LPF isn't going to help you. All your LPF does is stops frequencies above a certain point so the sub isn't playing anything out of it's response range. Your LPF should be set fairly close to your HPF settings on your speakers.
    A sub sonic filter will help you get the most out of a smaller driver, but if your sub is happy handling the lows with the amount of power on tap from your amplifier then theres no need for one in this case.
    Had you have bought a dual voice coil and you would have had plenty of head room.
  1. [SA] FS: Cheap / Free Random Parts at Random Prices
    By Dan355 in forum Parts And Other Items For Sale
    Last Post: 05-10-2010, 01:38 PM
  2. vp v6 popping on idle
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2010, 10:27 AM
  3. popping noise through air box..
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2008, 04:10 PM
  4. Popping up everywhere
    By Nobody Actually in forum The Pub
    Last Post: 19-10-2006, 10:09 PM
  5. vt popping noise
    By bok in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2005, 03:08 PM
