hey people, did a search but just want to have someone clarify some points before i ruch into connecting up my new head unit with no dramas...
firstly, the colours and their uses for the new head unit are as follows:
Black - Earth
Yellow - Constant 12v
Red - Accessory Terminal
Blue - automatic antenna
Blue w white stripe - remote lead
Orange w white stripe - to car light control switch
now the wiring as far as i know with the stock headunit wiring is as:
Accesories - Yellow
Constant - Orange/White
Illumination - Brown/White
Earth - Black/White
12V OUTPUT - Yellow/Red
Radio Mute - Yellow/Black (VT onwards)
Antenna up - White (VR onwards)
Antenna down - Blue (VR onwards)
Illumination OUTPUT - Grey (VT onwards)
now i find myself pretty good with soldering and wiring as such, but just want to double check before i ruin things. is this correct in the wiring?
constant on vz to constant on jvc
ground to ground (obvious)
accessories on vz to accessory terminal on jvc???
Antenae???
illumination on vz to car light control switch on jvc???
the ones with ??? are the ones i want to double check, and the antenae, do i connect to ant up or ant. down?
also do the wires such as mute, do i just tape up and leave them?
appreciate all the help
