Results 1 to 6 of 6
Thread: 2010 TK Barina Sub Install
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default 2010 TK Barina Sub Install
    Hey guys, a mate has asked me to see if i can install a sub/amp in his friends TK Barina (2010)
    Anyone know how to take the dash apart, if they have RCA/sub outputs on the back of the standard head unit, etc etc
    Any info is much appreciated. Also it's a manual so finding a place for the amp power wire to go through will be fun.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    You won't find any rca pre outs on the factory unit.
    You'll either have to use a line out convertor (LOC) or most amps these days have high level inputs for connecting without RCA's.
    No advice on the dash sorry never done a new model Barina.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by HCVP View Post
    Thanks heaps for the reply man, Can you explain what LOC and High Level Inputs are? Have only worked with RCAs thus far
    Having trouble finding any info at all about any barina let alone the newest one. It might have an amp already for all I know.
    Mar 2009
    Cairns White Rock
    A line out convertor takes a speaker wire signal which is a high level, and converts it to a low level signal which is more suitable for amplifiers.
    Basically you have an input on the convertor which is where the speaker wire connects, and on the output side is an RCA output. So, speaker wire in, RCA cable out. RCA cable obviously then connects to the amplifiers input.
    Any line out convertor should come with basic instructions when you buy one anyway.
    A high level input is just using existing speaker wire connected directly to the amp itself. You will see on most amps it has "high level inputs" basically this gives you the option to connect the amplifier when you don't have either a line out convertor, or an aftermarket head unit with dedicated pre-outs.
    There's no pre-outs or amplifiers or anything in the Barinas so your only choice without fitting an aftermarket head unit would be one of the above two options.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Ahh fantastic! Thanks for explaining that. Ok well I think she's already bought an amp so I'll have to take a look at that, we might not even "need" to take the dash apart - bar running the amp power cable... but I think it's a manual so no easy way out there.
    VT commodore 98
    Jan 2009
    hi i have the exact same car, i thinking about doing this also so please keep me posted on how u go, i have a amp with High level output but i lost the wiring loom lol., so im prolly gona go with the line out option.
    cheers
  1. A different Barina
    By PaulSV6 in forum The Pub
    Last Post: 16-07-2009, 02:57 AM
  2. Barina
    By cmarico in forum General
    Last Post: 10-05-2007, 09:58 PM
  3. 05/06 Barina
    By Hot-Rod in forum The Pub
    Last Post: 22-02-2006, 03:02 PM
  4. 91 barina
    By Garth in forum General
    Last Post: 11-11-2004, 06:01 PM
