Results 1 to 5 of 5
Thread: wiring problems with my new sound system!
    2002 VX Commodore Series II
    Jan 2011
    Default wiring problems with my new sound system!
    i got a 2002 vx commodore series 2, just replaced stock stereo with 7'' touch screen stereo and subs etc speakers amp etx work fine its just the ariel now will not come up when stereo is turned on ? i need like a wiring diagram to help me out , i wired it manually , cut plug off and done it all meself , normally a wizz at things like this but things didnt go to plan this time round. any help would be much appreciated
    fsa
    Jan 2011
    usa
    If i'm misslead please inform me as this in all new to me. I'm at the stage where i am trying to learn about things other than basic components and i'm struggling given my only methods are online researching.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    NNNNNNNNNNOOOOOOOOOOOOOOO
    why wont people be lazy for fs anyway i did similar not long ago bought an ISO connector off ebay all works one plug
    but future reference now i guess!~
    basically if you have cut the plugs off i cant tell you which pin it is so........
    your stereo should have an "electric aerial/antenna" wire labelled out the back of it?
    attach one end of a test light to this wire (touching wire duh)
    ign on AND stereo on
    start probing the wirning with the other end of test light
    (led one fine and led one wont fry other LIGHT circuits in that harness e.g. stereo cntrls blah blah blah)
    until the aerial goes up
    (will take a 2 second signal with a single led test light to start aerial moving)
    once found CONNECT IT (DUH)
    this without connectors in car is only way i can think of directly finding the correct wire that need the small amperage power signal to operate switch unit for aerial
    good luck!~
    Feb 2011
    usa
    I've also never done the patch test thingy which probably does make me stupid lol cause i guess i could one day have a reaction that could have been avoided so even tho I don't do it I would definately make sure you do the test.
    VX S-pack Commodore
    Mar 2011
    NSW Albury
    hay iv got a 2001 vx s-pack commodore and when i went to wire up my 6x9s into the rear door speaker wires i say that there were about 50 different wires going into each rear door all bundled up. so my question is which wires are the speaker wires and which ones are negative and positive and how hard is it to actually got into the wires
    (i am willing to lose the rear speakers completely so that my 6x9s cand work in the parcel shelf)
    (i have checked heaps of other threads and links on the net but nothing is exactly simple to follow and lead me down a dead end so any help will be grate)
  1. Sound System Problems
    By 03VY-Dungy in forum Car Audio
    Last Post: 22-11-2010, 08:38 AM
  2. Replies: 4
    Last Post: 26-01-2010, 02:31 PM
  3. [SA] Entertainment System (TV/Amp/Sound System) Selling Sep, Together OR Trade
    By boddyy in forum Parts And Other Items For Sale
    Last Post: 25-12-2009, 02:14 PM
  4. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  5. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
Tags for this Thread
