Results 1 to 9 of 9
Thread: Troubles and more troubles Please Help
    VX EXECUTIVE SERIES II
    Dec 2006
    Mildura
    Default Troubles and more troubles Please Help
    hi, i've got a bit of a dilema, i'm running a Jensen VM9212N head unit, Jensen Power 920 4 channel amp, Jensen 6 1/2" splits in the front, Jensen 6 1/2" in the rear doors and Jensen 6x9's in the rear parcel shelf, as a temp measure I had a clarion 4 channel running as 2 channel powering the 4 front speakers and a pioneer 2 channel powering the rears, all good no problems it was loud as hell, then I got the Power 920 and used it as a 2 channel along with the Pioneer, still all was good, then I decided to use the 920 as a 4 channel on its own, PROBLEMS AAAARGH, first there is the horrid whine from all the speakers when the car is on, this gets higher pitched under acceleration, so I tried my clarion 4 channel, this produces a constant high pitched noise when using all 4 channels, if I run 2 amps as 2 channel each I do not get this problem at all, i've tried these things to remedy the thing but to no avail,
    1. checked earth at the amp and the head unit, created a common earth, no joy there
    2. rerouted cables so there's no power wires near the rca leads, no joy there
    3. ripped it all out and started again with the same results using all combinations of amps, no joy there
    4. swapped the rca leads around but no joy there
    using one amp as a 4 channel amp, If I pull channel 1 & 2 out of the amp but leave channels 3 & 4 plugged in I get no noise, if I pull 3 & 4 out but leave channels 1 & 2 plugged in the same result, happens with both 4 channel amps
    I have a VT that has the same h/unit and leads the only difference is the amps, 2x 2channel Jensen Power 400's never had a problem that setup, am I up sh*t creek trying to use a 4 channel amp or should I stick to two 2channel amps, it does solve the problem if I do that.
    I've seen a few cars with the same 4 channel setup from Jensen as mine and they don't have this problem with noise at all
    I hear voices in my head and they don't like you
    VL Wagon
    Aug 2010
    Adelaide, Australia
    Quote Originally Posted by LES2010 View Post
    see, I read that bit, and thought "well there's your first problem"
    but it just kept going on!
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    My first rule in car audio is don't buy gear from Repco.
    Anyway, "I had a clarion 4 channel running as 2 channel powering the 4 front speakers and a pioneer 2 channel powering the rears" , do you mean the 2 front speakers or was there 4?
    EDIT: Also how are you splitting the RCAs to make them 4-channel amps. Or are you leaving the RCAs the same as when in bridged mode. Because that wouldn't work at all.
    Ronald Reagan (1986)
    VX Berlina
    Apr 2007
    On second thoughts, just give us the model numbers of all the components and I will make you a wiring diagram to try.
    And if you don't have the speakers model numbers than give me the RMS power ratings.
    Dec 2006
    Mildura
    G'day Acarmody, the h/u is a VM9212n, the front splits are powerplus us652c (6 1/2"), the rear doors have powerplus us652 (6 1/2"), the rear parcel shelf has powerplus us693 (6x9), the amp is a powerplus920, the rca leada are Aerpro, and many thanks.
    Les
    Dec 2006
    Mildura
    Quote Originally Posted by AmmoJammo View Post
    Bwahaha!!!!!!
    doesn't it always
    VX Berlina
    Apr 2007
    What about the Clarion amp, what model is it? Your not going to run 6 speakers with one amp properly.
    Well theoretically you could wire it up to drive all 6 but you will be pushing that amp to its breaking point. Leave the Clarion in. I trust Clarion a lot more than Jenson.
    Dec 2006
    Mildura
    Clarion amp is a APA4204
    VX Berlina
    Apr 2007
    Try this. This way your 6x9" act as (kind off) subs, since you already have 4 door speakers.
  1. car troubles please help!!!
    By VPS2 in forum General
    Last Post: 04-03-2009, 09:28 AM
  2. VL troubles
    By maxpower QLD in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2008, 07:27 PM
  3. Car Troubles
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2006, 06:35 PM
  4. VH 253 troubles
    By Portunio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-05-2006, 08:09 PM
  5. sub box troubles HELP please
    By mistervr94v6 in forum Car Audio
    Last Post: 04-09-2005, 06:56 PM
